- July 5, 2003
- Brockton, MA
- '93 XLT 4x4
My restoration project actually started out as just a weekend project to replace my Radius arm bushings. Unfortunately as I got into the tear down I kept discovering worn parts that needed to be replaced. So instead of just replacing the Radus arm bushings I ended up replacing every single factory suspension bushing with an Energy suspension Polyurethane counterpart... I also replaced all body mounts with Polyurethane Bushings from DayStar (see my DayStar Body Mount install thread for info and pics) As I was tearing into everything I decided It would be best just to do everying at once and get it over with. Therefore after removing everything I wired brushed and sandblasted all metal parts down to bar metal and coated everything with POR-15.
For additional info see Ted's 1st Gen Ball and U-joint replacement
New Ball joints, U-joints, Outer tie rods
Radius arm bushings, Axle Pivot Bushings, Sway bar bushings.
Rotors, Wheel Bearings, Spindle Bearings, Axle Seals, brakes
Bushings (Energy Suspension)
Radius Arm 4.7110
Axle Pivot 4.3133
Front Sway Bar 4.5115
Rear Sway bar 4.5116
Leaf Springs 4.2124
Ball joints (Moog) greasable Rockauto.com
Upper (2) K8546
Lower (2) K8563
U-Joints (Brute Force)
Wheel Joints (3) 1-0297BF (front axle U-joints 1 drivers, 2 pass)
Front Shaft (3) 1-0153BF
Rear Shaft (2) 1-0153BF
Brakes
Rotors (2) Lappens (lifetime warranty)
Wheel Bearings (4) Timkin LM
Wheel Seals (2) 4950
Pads Front
Pins caliper (4)
Hoses Left F130435 (Wagner) Rockauto.com
Right F130436 (Wagner)
Spindle 40-50ft/lbs
Bearing (2) (Timkin B2110) {within the spindle}
Seal inner (2) (Motorcraft BRS-88 F3TZ-1S175-AA) {End of spindle}
Seal outer (2) (Timkin 722109) {Attached to the stub Axle}
Tie Rod (Perfect Circle) Autozone
Outer L DS1177
Outer R DS1176
Oxygen Sensor (2) Bosch 7115
Here is a picture of the Right side coil spring retainer nut being removed.
TTB, Radius Arm and Sway bar mounted bracket
Radius arm after being wire brushed.
Here is the double cardan front drive shaft.
Here are the TTBeams Sandblasted, washed, and ready for some Por-15
Restored Radius Arm Mounting brackets.
Steering Knuckle with new Moog ball joints and ABS sensor protector. 6mm x 1.00 cap bolt
Here is the TTB Dana 35 restored and ready for re-installation. New Energy Suspension Axle pivot bushings.
Restored Left side.
Radius Arm 4.7110
Axle Pivot 4.3133
Leaf Springs 4.2124
Upper (2) K8546
Lower (2) K8563
Brakes
Pads Front
Pins caliper (4)
Spindle 40-50ft/lbs
Outer L DS1177
Outer R DS1176
Restored Left side.
