Lowering your Wiper Arms
Before you do this mod, sit in your explorer and get a good feel for the position of the stock wipers from inside the truck. Really look at the view out the front when they are totally stock so you can tell the difference after you do this mod to see if it's worth it for you.
While this mod does look cool from the outside, it's really on the inside where you will notice a clean view of the hood and a less clutered view in general from the driver and passenger seat.
To remove the wiper arm, simply pull that little latch out, fold the wiper arm back and pull it off. Make sure that little tab is completely out (you might have to hold it out) or the wiper arm won't lift off. No tools are needed.
To re-install, slide them back on, push the little tab back into the arm and lower the arm.
While doing this mod, you might want to turn the wipers on / off to test your settings. Turn them on / off before you do anything to make sure you got the default arm position.
You want to ensure you don't lower the arms completely onto the plastic lower cowl, but just touching or above should be ok.
