| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Front Wheel Bearing replacement
I had a terrible grinding noise coming front end. I suspected it was a bad wheel bearing and after jaking it up that seems to be the case. The wheel had a ton of play in it. I guess these all-wheel drive units have sealed bearings. I took it all apart but was unable to get to the actual bearing.
Do I need to buy a new bearing carrier? or whatever it's called. It doesn't seem to come apart. Also does anyone know the torque spec for the big nut that holds it on. thanks Thomas |
#2 |
Old and in the way
Humboldt, Kansas
2000 Mounty
#3 |
Fresno, California
'00 FX4 Ranger
Hub bearing.. You need to buy the entire hub to replace the bearing. They go around $200 from your local auto part.
__________________ 1. XLT Ranger 4dr 4.0 5 spd 4X4-> K&N filter, grill insert, Stainless steel skid plate, 98 Mountaineer front axles swap, factory motor transplanted and new clutch kit, 3" Flowmaster 40 dual outlet, hard bedcover, JamesDuff traction bars, Bilstien shocks. 2. 1999 K1200RS BMW motorcycle <fast German technology> 3. 2005 Suzuki XL 7, the only small SUV with 7 passengers I could effort under $15K 4. 1970 VW project -needs exhaust, interior, extrical parts.. |
#4 |
Fort Drum NY
2000 xls
135 autozone last time i bought one, last year jan.
torque specs: wheel hub nut = 157 - 214 hub and bearing assembly to steering knuckle bolt = 70 to 80 if you decide to reuse the nut (your decision) torque on the middle to high end. I've reused mine and i torque till my big butt cant move it with a 6 breaker bar. my torque wrench hits 200 and it seems like its not tight enough. So i add a break bar and finish the last few turns. __________________ Oh no i am at it again |
#5 |
Fresno, California
'00 FX4 Ranger
I reuse my nuts but uses loctite onto it. Just make sure you get those bearing with "Lifetime replacment" bearing. You'll be glad you do if the otherside go bad..
#6 |
Ridgecrest, CA
1998 XLT 4X4
1998 4x4 4.0 Xvin all stock Explorer. I have a whining noise that seems to be coming from the left front wheel. I am assuming wheel bearing problems. Has anyone had this same problem and found it to be something different. I know this type of noise can travel through the drivetrain.
#7 |
98 Sport
"1998 4x4 4.0 Xvin all stock Explorer. I have a whining noise that seems to be coming from the left front wheel. I am assuming wheel bearing problems. Has anyone had this same problem and found it to be something different. I know this type of noise can travel through the drivetrain. "
could it be this: NOISE—“SQUEALING” OR “WHISTLING” NOISE Article No.01-11-4 FROM FRONT AXLE AREA—DRIVING AT SPEEDS OF 16-64 KM/H (10-40 MPH)—4X4 VEHICLES ONLY—REVISED FRONT OUTER HALFSHAFT DUST SEALS • FRONT AXLE—“SQUEALING” OR “WHISTLING” NOISE FROM FRONT AXLE AREA—DRIVING AT SPEEDS OF 16-64 KM/H (10-40 MPH)—4X4 VEHICLES ONLY—REVISED FRONT OUTER HALFSHAFT DUST SEALS FORD: 1998-2001 EXPLORER 2000-2001 RANGER 2001 EXPLORER SPORT TRAC, EXPLORER SPORT MERCURY: 1998-2001 MOUNTAINEER ISSUE Some 4X4 vehicles may exhibit a high-pitched “squeal” or “whistle” type noise from the front of the vehicle at speeds from 16 to 64 km/h (10 to 40 3. mph). This noise may be caused by the front halfshaft excluder (dust) seals as they rotate against the inner front hubs. The noise may be more pronounced in cold weather conditions. ACTION Install new front halfshaft excluder seals on each side of the vehicle. |
#8 |
brooklyn, new york
2003 Eddie
need some help
when I turn left or right and depending on the weather I would get a loud grinding noise coming from the wheel i at first taught it was the cv axle so I replace my cv axle turns out its not the axle . I guessing its the wheel bearing ? how can I make sure its the bearing ?Dont want to spend the 200 for a new one and its not the bearing
thanks |
#9 |
schroon lake new york
2000 xlt awd
wheel bearing
just replaced one on my wifes 07 explorer ironman, it was the drivers side no question about that. i got mine from ford for 270.00 ive replaced them on our old explorer from advance auto but only got a year out of them .. if yours is all wheel drive the only way to really tell is to take it off .
#10 |
in the mud & sticks-Hillsboro, Wisconsin
2001 Eddie Bauer
cheap alternative is ebay
__________________ -2001 Explorer 4x4 Eddie Bauer 5.0, SuperChips tuner, custom cat-back exhaust, 265/75/16 DuraTracs, Customized BBPfab bumper, KC DayLighters, 2" TT lift, 3" AAL lift. Rancho 5000s. Alpine Stereo System w/ 12" subwoofers x2, & more Pics & Specs -1977 F-250 longbox, 9" lift, 460ci big block, NP205 transfercase, Dana 60 front axle, Dana 70 rear axle, 44" Denman Groundhawgs, American Racing wheels, custom bumpers & more. Pictures to prove it Here and Here. happy muddin! |
#11 |
So, I replaced the drivers side bearing after a garage hosed me on the installation of the passenger bering. All my growling went away for a few weeks, and now I have the growling/whining noise coming from the left front again.
Did I do something wrong during the installation or is there a possibility that I need to check another part that is causing the noise? __________________ 1999 Eddie Bauer Explorer 4.0, AWD SOHC |
#12 | |
Living in Greenland
Holland, MI
'00 V8 XLT
Did you make all torque specs?
What kind/brand of bearings did you use? __________________ Quote:
#13 |
Torque specs, haha. My wrench did not go that high, so I eyeballed it. Part was from 1A auto parts
#14 | |
Living in Greenland
Holland, MI
'00 V8 XLT
But are the parts Timken bearings or the cheaper ones? The cheaper ones are known to fail fast for a lot of people.
If you don't know that you made torque, the hubs may have been loose enough to grenade that fast. It's important to meet that spec for the Ex hubs. __________________ Quote:
#15 |
I promise you the nuts were on there tight. That would really suck if the bearing went bad again. ANy way to quiet the noise without replacing it?
#16 |
Atlanta
98 Mountaineer
I purchased the cheap Ebay hub once, only to discover that the ABS sensor part of it was bad. After installation, my Antilock brake system light illuminated.
. I tried many different things to get it to go off, over a 3 month time period. Finally, I just installed a better HUB, and the problem went away. |
#17 | |
Living in Greenland
Holland, MI
'00 V8 XLT
Nope, if it's bad, it's bad. No way to "mask" the issue that won't reintroduce itself shortly.
#18 |
Is there anything else up front that could be causing this noise? Any way to isolate before ordering a new bearing?
#19 |
2000 Sport, 5M OHV RWD
Rockauto has Timken bearings for $101 (before 5%) discount. Just get a good hub and forget about it, don't bother with the cheap ones. It's not worth the aggravation or potential safety hazard.
Advance also has Moog (National) bearings for $138, but you can get $30 off that using code BIG30. I don't know if Moog or Timken is better. |
#20 | |
Bristol RI
'96 XLT
Quote:
__________________ Don't worry I'll go through first. |
| Thread Tools | |
