Tony H
- September 4, 2003
- New York, Wading River (that's on Long Island)
- '91 Eddie Bauer
It was late and it was nowing so pleae don't say "Crawl under and look"
'91 Stock 'X' looking at the PLUS Battery terminal. One red wire 9Smaller one) runs to the Starter Relay inside the Loom with small wire that runs to the Starter ( I assume). The problem is the Big honk'n wire that is also part of Battery Terminal. It runs a down then out of sight. Does that run to the Starer also?
Last night I had a very slow start issue so as I went to clean the terminals can see that this Plus Terminal was all broken up where the wires go into the Terminal. I had a Terminal from my boat. The kind with the Wing nut on top. So I cut and Lugged the two wires and put on the new Terminal. I want to just go ahead and replace the wires but all together. Just need to know how much wire I need to " liberate" from work for that Heavy gauged wire.
