grn03exp
- February 22, 2007
- Lake Orion, Michigan
- 2003 XLS 4x4
2003 Explorer XLS 4.0L/Auto
Auto 4x4
43,500 Miles
I just bought this explorer about a week ago, and i just took it out on the freeway for the first time yesterday. I noticed from about 55 to 65mph there is a howl from the rear end. It starts at a very low freq and very quiet at 55 and gets progressively higher in pitch and louder all the way up to 65 and then it just stops howling. It only howls under load, so if im in the range, and i let off the gas, it stops howling. Ive searched, and i cant find anything directly relating to this. As i understand it, the common rear end whine or howl is caused by the limited slip rear end and a lack of friction modifier from the factory. I dont think i have a LS rear end because i dont have the towing package. Well i dont think i have the towing package, my hitch reciever is only a 1 1/4 inch.
I was wondering two things:
1. If i just ignore the howl, will there be any real damage done to the rear end, or shorten its life span. I can live with the howl if it isnt doing any damage, its not very loud.
2. Is there anything i can do to lessen or eliminate the howl, or would this be a warranty issue, i do have a RoyalShield warranty from the dealership i bought it at, but only for 3 mo / 4000 mi (it came with the purchase of the truck) so if it is, i need to take care of it soon.
It bugs me because i used to wheel jeeps and i know that howl is from poorly setup gears, and at the very least the excessive lash shortens the life span of the gears and at the worst, ive seen rear ends completely lock up because of wear incurred from excessive lash.
TIA
Ron
Auto 4x4
43,500 Miles
TIA
Ron
