| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
Fairfax, VA
02 XLT
Transmission Torque converter drain???
Hey guys. I have just purchased a used ford explorer 2002. I am changing all the fluids including the transmission. I know i have the sealed transmission and have to fill it using that fill port on the bottom.
Does the transmission have a torque converter drain plug? Is it a good idea to remove the pan and change the filter as well? I'm excited to see how the fluid looks after 80,000 miles. I will be more than happy to take pictures and put them on here too! Thanks all |
#2 |
Towing Moderator
North East Arkansas
2012 F150 4x4
I don't believe the torque converter has a drain. Most people pull a line off of the front tranny cooler to change their fluid, of course you want to drop the pan and change the filter.
http://www.explorerforum.com/forums/...ad.php?t=77507 __________________ -Evan Febuary 09 Feature Truck - Elite Registry - Photo Gallery - Feedback - Go Elite! - My Write Ups - EF Vendors |
#3 |
Fairfax, VA
02 XLT
Thanks! I've heard some people say that there is a fill plug on the side of the sealed transmission... is this true?!
#4 |
Towing Moderator
North East Arkansas
2012 F150 4x4
I don't really know- not too familiar with the 3rd gen drivetrain. I'd think there is a plug on there somewhere, but don't know there.
I'd suggest you search some different keywords on here, you will probably find your answer. In the meantime, maybe someone else will jump in here. __________________ -Evan Febuary 09 Feature Truck - Elite Registry - Photo Gallery - Feedback - Go Elite! - My Write Ups - EF Vendors |
#5 |
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
The 5R55W has a fill plug on the side of the case located at the back on the passenger side. It also has a torque convertor drain plug.
The 5R55E has neither. |
#6 |
Fairfax, VA
02 XLT
Glacier991, where is that torque converter drain located?! I can't find it! Thanks! --also after draining the torque convertor, how much fluid am I looking to put back in? 18 quarts I've read?
#7 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
more like 8 quarts with a pan drop.
If your converter has a drain there should be a rubber plug directly under the converter, then you turn the crankshaft over by hand or bump the starter, until the drain comes into view Is your 02 a V6 or V8? __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#8 |
Fairfax, VA
02 XLT
Great, thanks. Anyone have any pictures of this torque converter rubber plug?
#9 |
EF Tranny Guru
1992 XLT
If you have a 5R55W at the bottom of the bellhousing there will be a black rubber plug about the size of a silver dollar. If you have a 5R55E there won't be one.
#10 |
Fairfax, VA
02 XLT
thanks guys! i got the job done except i'm not sure about what temp. the transmission is at when I check the fluid. I know some people on here have put transmission temp. guages but I'm not hauling anything to need it. Which scan tool do people use to get the transmission temp? I want to be sure the fluid is at the right temp..
and off subject. does anyone know what size that plug is on the read diff drain? Its huge! |
#11 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! Check the above sticky threads, such as the 5R55W fluid fill, and installing a transmission temperature gauge. They should answer all of your questions. Both have excellent illustrations.
| Thread Tools | |
