#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Camshaft Position Sensor?
Reply
Thread Tools
Old 03-13-2007, 09:43 AM   #1
Lazzman
Massachusetts
1998 Sport 4wd- V6 Sohc
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Does anyone know how many Cam position sensor a 4.0 sohc motor has?
I know there is one on the top of the driver side valve cover but is their another one somewhere?
Thanks
Lazzman is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-13-2007, 10:38 AM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
yes there is another on the back of the engine block just like the earlier OHV
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 03-13-2007, 01:17 PM   #3
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Thanks 410 I thought so. Different auto parts stores were giving me different parts.
Is the rear one visible? How hard is it to locate?
Old 03-14-2007, 07:18 PM   #4
zubi
Miami, Florida
1996 Limited
Vehicle Specs
Quoted: 0 Post(s)
If its like my 1996 4.0, its not visible to the bare eye, you need a mirror. I just replaced mine, what a pain, no room!!
zubi is offline   Reply With Quote
Old 03-15-2007, 01:09 PM   #5
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Do you have the SOCH or OHV?
Why does the sohc motor have two Cam position sensors? One on the valve cover and one in the back of the engine?
Old 03-15-2007, 01:39 PM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
It has two because one is used to startup in the traditional manner, to engage spark timing and fuel injector firing (tells the computer the engine is rotating) and the valve cover mounted sensor is for the actual cam signal and position to the computer so it can control/monitor valve timing.
probably because the OHV had one on the back of the engine, driven by the oil pump, and the SOHC has a "dummy" cam still in the top of the block
Your second sensor is on teh back of the engine, above the transmission spine, behind the upper intake manifold, a real PITA to access without removing the intakes
We know all this because of Brett's SOHC conversion using the OHV computer to run things (his valve cover mounted cam sensor is hooked up to nothing)
__________________
Old 03-15-2007, 06:51 PM   #7
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
So your saying that it makes no sense to replace the valve cover mounted Cam sensor?
Old 03-15-2007, 08:50 PM   #8
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Lazz, do you have problems withthe cam sensor?
How did you determine it?
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 03-15-2007, 10:46 PM   #9
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
With a scan tool.
Old 03-21-2007, 07:47 PM   #10
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Somebody is mistaken here. The Ford dealer told me that there is only one cam position sensor for the sohc v6 engine and it is mounted on the valve cover.
The OHV V6 has the dummy cam sensor where the rotor was. Also my Ford manual only shows one Camshaft position sensor.
Does anyone know the truth? Is it one or two?
Old 03-21-2007, 09:37 PM   #11
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
There is one.
__________________
Al Franklin
My truck
My Quest for 30
Old 03-22-2007, 10:14 AM   #12
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Thanks AL
Old 04-04-2007, 10:28 PM   #13
matz162008
Vehicle Specs
Quoted: 0 Post(s)
where is it at on a 4.0 ohv?
matz162008 is offline   Reply With Quote
Old 04-05-2007, 11:51 AM   #14
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
Allright listen up people
94+ OHV has a cam sensor, it is located at the back of the upper intake manifold:
the 97-2004 SOHC has this sensor ALSO and the valve cover mounted sensor.
There is no CAM/lifters/pushrods in the SOHC where the OHV cam used to be BUT there is a DUMMY cam in there because this is what drives the oil pump.
I am not sure about 2005+ but I am gonna go out on a limb and say its still there.....
The SOHC definatley has two cam sensors, one is actually used to tell the computer the over head cam position/speed/etc the one on the back of the block is still only used for initial start up.
When Brett did his SOHC conversion he had to make some wiring changes to accomodate the oil pump shaft mounted 2004 SOHC cam sensor, completely ignoring the valve cover mounted sensor because he is using a OHV computer.
I believe I already said all this, but um yeah if your Ford dealer says there is only one well then there must only be one, right? Dont lsiten to the people who actually pull these engines and work on them or with them, listen to the parts guy at the counter! hahahaha
both OHV and SOHC have a cam sensor mounted right here:
__________________
Old 04-05-2007, 02:27 PM   #15
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Thanks for clarifying 410
How in the hell do you replace that one? Just the sensor not the whole shaft assembly? That space looks way tight when the engine is mounted in the truck.
Thanks for any help.
Old 04-05-2007, 04:19 PM   #16
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
remove everything down to the upper intake manifold then you can pull it out of the block.
Space is tight.
I was actually able to install one without removing the upper intake but the engine was basically bare aside from that and I did it mostly by feel
__________________
Old 04-05-2007, 07:36 PM   #17
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 186 Post(s)
Jamie, does this look familier, this is the back of my 99 SOHC?
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 04-05-2007, 09:18 PM   #18
tmh6202
Lincoln Park MI
1998 Explorer Sport 2dr.
Vehicle Specs
Quoted: 0 Post(s)
Cam Sensor
Sorry to disagree 410, but like CDW's 99, my 98 SOHC has only one on the valve cover. No sensor on the rear of the block for start up or any other purpose. (See photo) However, there is something in the top center of the block which could be a sensor, but not for a cam since they are in the heads.(see photo2)
Also, the "dummy" camshaft is a jackshaft that runs the oil pump and the rear timing chain on the passenger side of the engine. Which runs through the block right under this "thing" on the block. Note that the old distributor hole is capped and bolted, the head of the bolt is visible under the crankcase vent filter box.
Mr. H.
__________________
Someone once asked me what I make...I make a difference, one day at a time, one student at a time...what do you make?
Having a great mind means nothing if it is not used.
tmh6202 is offline   Reply With Quote
Old 04-05-2007, 09:57 PM   #19
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by tmh6202 View Post
Sorry to disagree 410, but like CDW's 99, my 98 SOHC has only one on the valve cover. .
Same on my '99.
__________________
Al Franklin
My truck
My Quest for 30
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
