kymadan
- September 26, 2006
- Eustis, Fla
- '87 4x4 Ranger
Transmission and transfer Case specs and useage.
Here are the specs up of the transmissions lengths, tranny gears, axle codes, transfer case gears, etc....
Trans.............. Years...... Code... 1st.... 2nd.... 3rd.... 4th.... 5th..... Length
C3................ 1983-1984.... V .... 2.46.... 1.46.... 1.0....................... Overall length is 24-inches
C5................ 1982-1986.... W .... 2.46.... 1.46.... 1.0....................... Overall length is ???
A4LD..............1984-1994....T .... 2.47.... 1.37.... 1.0.... 0.74.............. Overall length is 28.687-inches
4R70W........... 1996-2000.... U .... 2.84.... 1.55.... 1.0.... 0.70............. Overall length is ???
4R44E............ 1995-2000.... T .... 2.47.... 1.37.... 1.0.... 0.75............. Overall length is ???
4R55E............ 1995-2001.... T .... 2.47.... 1.37.... 1.0.... 0.75.............. Overall length is ???
FM145........... 1985- 1992.... ? .... 3.72.... 2.20.... 1.50.... 1.0.... 0.79.... Overall length is ???
5R55E............ 1997-2000.... D .... 2.47.... 1.87.... 1.47.... 1.0.... 0.75.... Overall length is 29.25
M5OD R1........ 1992-1996.... D .... 3.72.... 2.25.... 1.50.... 1.0.... 0.79.... Overall length is 29.25
M5OD R2........ 1997-1999.... M .... 3.91.... 2.24.... 1.49.... 1.0.... 0.80.... Overall length is ???
Toyo-Kogo 5... 1983-1985.... 5 .... 3.96 .....??? .... ??? .... ??? .... 0.85.... Overall length for the 4x4 is 25.937-Inches
If you have a Ranger newer than 1988 with a manual transmission AND DO NOT HAVE A 2.9 ENGINE you have a MAZDA M5OD-R1.
If you have an 1988-1992 Ranger or Bronco II (1988-1990) with a manual transmission and 2.9 engine you can still have a Mazda transmission but a Mitsubishi is far more likely. The Mitsubishi has a bottom cover, a Mazda does not.
1983-1987 2wd Rangers and Aerostars (all engines) with Manual trans will be either a 4-speed or 5-speed "Toyo-Koygo" transmission. (Note: Aerostar 5sp only)
1983-1984 4x4 Rangers/Bronco II's (all engines) with Manual transmissions will be either a 4-speed or 5-speed "Toyo-Koygo" transmission.
1985-1987 4x4 (any engine) can be EITHER a Toyo-Koygo 5-speed (aka "T-K" or "Ranger-5") OR it can be a Mitsubishi FM145 5-speed manual (this transmission is 4x4 ONLY)
Toyo-Koygo's are more likely to be found in 4cyl 4x4 Rangers. Bronco II's are more likely
to be Mitsubishi FM145's
1988-1992 Rangers (4x4) / Bronco II (4x4 & 2wd) 2.9 engine can be;
1) Mitsubishi FM146 (2.9 4x4 ONLY)
2) Mazda M5OD-R1 (4x4 version)
1988-1992 Rangers 2wd equipped with the 2.9 engine there were both;
1) Mazda built M5OD-R1 (2wd Version)
2) Mitsubishi FM132 (2.9 2wd ONLY)
1988-current production Rangers with 4cyl engines both 2wd and 4x4 (including the 2.0 (carb), 2.3, 2.5 and (new) 2.3 DOHC will be a Mazda M5OD-R1. This is the only manual transmission factory installed behind four cylinder engines in Rangers after the beginning of the 1988 model year.
1988-1995 Aerostars with manual transmissions will have Mazda M5OD-R1 transmissions.
1991-current Rangers with the 3.0 engine:
The Mazda M5OD-R1 is the only manual transmission used in Rangers with this engine.
1991-2000 Ranger/Explorer with the 4.0OHV engine:
The Mazda M5OD-R1 is the only manual transmission used in Ranger/Explorer with this engine.
2001-on Ranger (1997-on in Explorers with the 4.0 SOHC engine):
the Mazda M5OD-R1HD is the only manual trans used in Rangers/Explorer with this engine.
NOTE: on Bronco II's ALL versions are equipped with 4x4 type transmissions,
because the 2wd Bronco II's use a "dummy" transfer case. I don't know why Ford did it this way, but that's the way they did it.
Bronco II's
A common thing to do to a 2wd Bronco II when the original transmission fails is to eliminate the dummy T-case and swap in a 2wd Ranger transmission.
2wd Ranger transmissions are FAR more common and proportionally less expensive than 4x4 transmissions.
Also swapping to a 2wd Ranger transmission allows the use of a longer driveshaft with conventional U-joints.
Vehicle................................#of Speeds.......Automatic transmissions used
Ford
Aerostar 82-86................................3..........................C5
Aerostar 85-95................................4 .........................A4LD
Aerostar (3.0L) 96-97.......................4.........................4R44E
Aerostar (4.0L) 1996........................4.........................4R55E
Aerostar (4.0L) 1997........................4.........................5R55E
Bronco II 1984.................................3........................C5
Bronco II 84-90................................4........................A4LD
Explorer 91-94..................................4........................A4LD
Explorer (4.0L) 95-01.........................4.......................4R44E, 5R55E
Explorer (5.0L) 96-01.........................4.......................4R70W
Explorer (4.0, 4.6L) 02-03...................5.......................5R55W
Explorer (4.0, 4.6L) 2004....................5.......................5R55S
Explorer Sport, Sport Trac 01-04.........5.......................5R55E
Ranger 83-84....................................3.......................C3
Ranger 82-86....................................3.......................C5
Ranger 85-94....................................4.......................A4LD
Ranger 95-01....................................4.......................4R44E, 4R55E
Ranger 97-04....................................5.......................5R44E, 5R55E
Mazda
Navajo 91-94.....................................4.......................A4LD
Pickup 82-89......................................3.......................L3N71B
Pickup 86-89......................................4.......................L4N71B
Pickup 90-93......................................4.......................L4N71B
Pickup 4wd 90-93...............................4........................R4A-EL (RE4R01A)
Pickup 1994.......................................4........................A4LD
Pickup 95-96......................................4........................4R44E/ 55E
Pickup (97-00 Exc 4.0L) 97-00..............4.......................4R44E/ 55E
Pickup (97-00 4.0L) 97-00....................5.......................5R55E
Pickup (2.3L) 01-04.............................5.......................5R44E
Pickup (2.5L) 2001...............................4......................4R44E
Pickup (3.0, 4.0L) 01-04.......................5.......................5R55E
Transfer Cases
BW 1350.....................Part-Time.....................Chain Drive.....................2.48:1
BW 1354.....................Part-Time.....................Chain Drive.....................2.48:1
BW4404.....................All-Wheel Drive...............Chain Drive.....................?
BW4405.....................?..................................Chain Drive.....................?
Axles
Explorer
Door Code
41..... Open 8.8"..... 3200..... 3.27
42..... Open 8.8"..... 3200..... 4.10
43..... Open 8.8"..... 3200..... 3.08
44..... Open 8.8"..... 3200..... 3.73
45..... Open 8.8"..... 3200..... 3.55
46..... Open 8.8"..... 3200..... 3.73
D1..... L/S 8.8"..... 3200..... 3.27
D2..... L/S 8.8"..... 3200..... 4.10
D4..... L/S 8.8"..... 3200..... 3.73
D5..... L/S 8.8"..... 3200..... 3.73
L73 ..... L/S ?.?"..... ????..... 3.73
Ranger
72..... open 6-7/8"..... 2200..... 3.08
74..... open 6-7/8"..... 2200..... 3.45
82..... open 7.5"..... 2750..... 3.08
84..... open 7.5"..... 2750..... 3.45
86..... open 7.5"..... 2750..... 3.73
87..... open 7.5"..... 2750..... 4.10
91..... open 8.8" ..... 2750..... 3.27
92..... open 8.8"..... 2750..... 3.08
95..... open 8.8"..... 2750..... 3.55
96..... open 8.8"..... 2750..... 3.73
97..... open 8.8"..... 2750..... 4.10
98..... open 8.8"..... 2750..... 4.56
F4..... L/S 7.5"..... 2750..... 3.45
F5..... L/S 7.5"..... 2750..... 3.55
F6..... L/S 7.5"..... 2750..... 3.73
F7..... L/S 7.5"..... 2750..... 4.10
R5..... L/S 8.8"..... 2750..... 3.55
R6..... L/S 8.8"..... 2750..... 3.73
R7..... L/S 8.8"..... 2750..... 4.10
R8..... L/S 8.8"..... 2750..... 4.56
KA..... Electric Vehicle ........ Electric Vehicle
Bronco II
42..... open 7.5"..... 2640..... 3.45
44..... open 7.5"..... 2640..... 3.73
47..... open 7.5"..... 2640..... 4.10
D2..... L/S 7.5"..... 2640..... 3.45
D4..... L/S 7.5"..... 2640..... 3.73
D7..... L/S 7.5"..... 2640..... 4.10
Aerostar
22..... open 7.5"..... 2950..... 4.10
23..... open 7.5"..... 2950..... 3.45
24..... open 7.5"..... 2950..... 3.73
25..... open 8.8"..... 2950..... 3.27
29..... open 8.8"..... 2950..... 3.55
B2..... L/S 7.5"..... 2950..... 4.10
B4..... L/S 7.5"..... 2950..... 3.73
B5..... L/S 8.8"..... 2950..... 3.55
B9..... L/S 8.8"..... 2950..... 3.55
Bronco II's
Ford
Mazda
Transfer Cases
Axles
Explorer
Door Code
Ranger
Bronco II
Aerostar
