Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac.
Reply
Thread Tools
Old 09-03-2007, 10:19 PM   #1
MountaineerGreen
Stock - Lifted - Stock
North East Arkansas
MountaineerGreen's Avatar
2001 5.0 MX4 Off Road
Vehicle Specs
How To: Upper Control Arm / Ball Joint Replacement (Lots of Pictures)
This is really simple, the only complication would be excessive rust or stuck parts. My truck being from the south, I am blessed with no rust.
To start, jack up the truck, remove the tire and wheel on the afflicted side. It should look like this:
Remove the rubber flap held to the fender liner by push retainers. You'll see the front and rear camber adjusters on the top side of the frame.
This is the back:
The front:
Note the position of the camber adjusters-
Remove the large nuts on the end of the camber adjuster bolts.
Remove the camber adjuster, bolt and cams on both sides.
See the flat side on the bolt?
Remove the pinch bolt from the knuckle
Knock the UCA upward, the arm should come out.
The new one and the old one:
The empty spot:
The new one replaced.
Its just the opposite of the removal procedure, I put the camber adjusters in the same spots as they were. I recommend getting an alignment after replacing the UCA.
Hope this helps.
MountaineerGreen is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 09-04-2007, 03:04 AM   #2
Lloyd10977
Chestnut Ridge NY
Lloyd10977's Avatar
1995 Limited
Vehicle Specs
Great series, although a bit late for me. I did mine about 4 months ago and basically followed the precedure you outlined. Piece O' cake.
__________________
Black , street stock, 1995 Ford Explorer Limited, 4.0L-OHV V6 with AirHog filter, iridium spark plugs w/Taylor wires, 4dr, auto w/tow package and 3.73 Traction-Lok rear, 4WD, 4 wheel disk brakes with ABS, with tan leather, sunroof and engine block heater, made in Canada. Rear leaf springs from a '78 Bronco 3" wide spring pack added to the stock 2.5" wide main spring, 1.2" lift.
Lloyd10977 is offline   Reply With Quote
Old 09-04-2007, 09:58 PM   #3
bob lawrence
Baton Rouge, LA
96 XLT 4WD
Vehicle Specs
trouble fitting the b/j stem into the knuckle
I'm putting new UCAs on my son's 98 Ranger (2wd, 4cyl). I bought them from Autozone (part #FA4054 for LH side; #FA5055 for RH side). I can't install the LH UCA, because the ball joint stem is larger than the slot on the knuckle. I compared it to the stem on the original UCA, and the new one appears to be a little larger in diameter. I've been able to expand the slot slightly by wedging a cold chisel into it, but can't expand it wide enough to allow the b/j stem to be inserted. Even if I were able to expand it more, I'm afraid it will cause the bolt holes to be misaligned. Any suggestions? Thanks.
bob lawrence is offline   Reply With Quote
Old 09-05-2007, 07:19 AM   #4
MountaineerGreen
North East Arkansas
Vehicle Specs
Take the part back, odds are you got the wrong one from AZ. I have gotten parts that the box was the right #, but the contents were wrong.
Old 09-08-2007, 10:15 AM   #5
bob lawrence
Baton Rouge, LA
96 XLT 4WD
Vehicle Specs
Stems on ball joints on both control arms were larger than OEM, and wouldn't fit into the knuckle. I took the arms back to Autozone and bought the correct ones from Advance Auto Parts. Had to order them from Advance, but they were delivered next day, so not too bad.
Part No. 10929 TRW Control Arm W/Ball Joint Frt Susp; Upper; RH; 2WD; w/Coil spring Susp. $83.44
Part No. 10930 TRW Control Arm W/Ball Joint Frt Susp; Upper; LH; 2WD; w/Coil spring Susp. $69.98
Old 09-08-2007, 11:11 AM   #6
MountaineerGreen
North East Arkansas
Vehicle Specs
I could see how a 2wd, coil spring would have a different upper control arm.
Old 09-08-2007, 11:59 AM   #7
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
Say Evan, where did you buy your upper arms from, how much, and was that the first time for the truck? I did just the upper Ford arms on my 98 Mounty when I bought it 76,000 miles ago. I have all new parts to do everything else now, and I haven't looked hard at my 76k uppers yet. Thanks for the good threads that you have done. I hope to do a BW4406 in mine sometime soon. Regards,
__________________
Don
99/93 SOHC Limited 4WD, 98 AWD Mounty with 255/60/18's, Zexel-Torsen diff, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans and a 347 for real HP.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 09-08-2007, 12:16 PM   #8
MountaineerGreen
North East Arkansas
Vehicle Specs
I got my drivers side upper from NAPA, it was just over $100, and has a greasable joint. I replaced it at ~135k. My passenger side (two piece) is stock and still good. I don't plan to replace it until I have to. When the time comes, I have a Moog on the shelf in the shop, its used, but for a short while. It should be fine.
Since I was doing a front end rehab, had the time and a digital camera, I thought I'd cover the how to's while I was it. We can't have the world largest Explorer community without write ups on common tasks.
Old 09-08-2007, 12:24 PM   #9
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
Thanks, if when I look at my uppers they don't look great, I might take a look at the NAPA part.
__________________
Don
Old 09-25-2007, 04:09 AM   #10
carguy101
Orlando and St. Augustine FL
'98 XLT 4X4 SOHC
Vehicle Specs
sorry its a dumb question, why would i need to replace my UCA? they looked about the same in your pictures but one was obviously cleaner
TIA
__________________
'98 Explorer XLT 4.0 SOHC 4X4
-Leather-Sunroof-
-Monroe Shocks-Sylvania Silverstar Bulbs-Husky Cargo Liner-New Trans-Hard Wired Valentine 1-more to come
carguy101 is offline   Reply With Quote
Old 09-25-2007, 07:12 AM   #11
MountaineerGreen
North East Arkansas
Vehicle Specs
When worn out the joint will move up and down in the bore, the new one was nice and tight. I didn't / couldn't diagnose it myself (truck assembled), I took it in for an alignment, they said I needed a new one. Once I removed it, it was obvious it was no good.
Old 10-31-2007, 01:09 PM   #12
matt98sport
Elliot Lake, ON
1998 Sport
Vehicle Specs
HEY there is a new RH UCA available from MOOG. the part number is a K80068, it is a direct replacement for the 2 piece design, it comes with control arm bushings and the same problem solver ball joint as the LH UCA. when i replace my ball joints, i will be going with the one piece design for the simple fact that it comes with control arm bushigns (which ALL of mine are completely F***ED!!!) i can feel my whole IFS system jiggle front and back at times in the bush and its a really annoying and uncomfortable movement. anyone else have this???
if your going to buy ball joints, go all out and get the MOOG ones because if you grease them they will literally outlast your vehicle!
check out moog's site if you are curiuos what a "powder metal gusher bearing" is.
it really is an incredible little piece of lubrication technology only MOOG has! they use this rather than grease veins and a nylon bearing.. lol...
i had a rep from federal mogul come in to my store and he did a demonstration with a piece of this metal and its mind boggling to see grease come out of a seemingly solid piece of metal.
matt98sport is offline   Reply With Quote
Old 11-03-2007, 05:09 PM   #13
CarolinaBlazer
Tampa, FL
'97 XLT
Vehicle Specs
Whats up yall. Thanks for the great instructions here. I'm having the eorst time trying to get the upper ball joint free from the knuckle. I've removed the pinch bolt and sprayed the thing down with PB Blaster, but it still wont budge. I've also tried using ball joint forks and a hammer. Any ideas?
__________________
-1997 Explorer XLT 4.0L 4x4, 108K mi.
-1996 Impala SS, 38K mi.
CarolinaBlazer is offline   Reply With Quote
Old 11-03-2007, 08:55 PM   #14
MountaineerGreen
North East Arkansas
Vehicle Specs
Take a short screwdriver or something to wedge in the crack on the back of the knuckle. That will spread it open and help the ball joint slip out. A mini sledge and a few whacks up on the UCA usually does it though.
Old 11-04-2007, 12:29 PM   #15
CarolinaBlazer
Tampa, FL
'97 XLT
Vehicle Specs
Thanks for the tip, Evan. I managed to get the tip of a ball joint fork in that slot and coax it to break free. Thanks again!
__________________
Old 11-07-2007, 03:42 AM   #16
Ford_Racing_Guy
Spencer, Wisconsin
'92 XLT & '98 XLT AWD
Vehicle Specs
what is the difference really between the 2 piece and 1 piece design for the right side?
it shouldn't be a problem to make the conversion should it?
__________________
92 - secondary trans cooler and aux filter, Custom Rust
1998 XLT - Kenwood headunit, MTX Thunder Amp and subwoofer, Magnaflow y-pipe Dynomax tailpip with summit glasspack
Ford_Racing_Guy is offline   Reply With Quote
Old 11-18-2007, 02:06 PM   #17
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Anyone have torque specs?
Upper ball-joint pinch bolt
Lower ball-joint castle nut
Tie rod castle nut
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 11-18-2007, 02:11 PM   #18
MountaineerGreen
North East Arkansas
Vehicle Specs
I lost my Ford CD when I moved, the link doesn't work anymore, so I don't know where to get specs. I just snuged em up and called it good.
Old 11-18-2007, 02:11 PM   #19
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Sorry.. My subsequent searching turned them up..
Torque specs..
Quote:
Originally Posted by Bill MacLeod
The following is from a 99 shop manual for 4x4 (all in ft.lb):
Lower b/j nut - 83 to 112
Hub to knuckle - 74 to 96
Pinch bolt - 35 to 46
Hub nut - 157 to 213
Tie rod - 51-73
Upper ctrl arm bolts/nuts - 83 to 112
Sway bar end link nuts - 25 to 34
__________________
Old 11-18-2007, 02:12 PM   #20
MountaineerGreen
North East Arkansas
Vehicle Specs
Thanks!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
