Jamieh560
- April 12, 2004
- Wilmington, NC
- '97 Sport
WELL I have been have problems with no power and rough idling and then misfires on 5 cylinders! No codes... No sensors acting up.... anything.... Then I noticed the harmonic balancer had a wobble to it. I was like how in the hell did it get bent??? When I went to remove it the bolt was a pain to get out and the Harmonic balancer fell off.... So I got to have a crankshaft. Whats fun is ford stealership had if off last when they did the front timing chain guide. well I have the engine out and apart here is some pics....
Here's the crank.. it wore the key down cause timing to be off quiet a bit....
Here's the rear guide broke....
I'm taking the heads and block to the machine shop on monday... milling and valve job for the heads.... decking the block for alittle more compresson. Has anyone bored out their engine... was there positive outcome.... Has anyone had there cams regrinded. I've ordered crankshaft and all timing components (all new chains, guides, and spockets.) I'm still looking for a rebuild kit for everything else without going to ford.... Thanks for any info... I'm post pics as I rebuild....
ALSO does anyone have the timing tool kit I could use for alittle cash... Hate to buy to use once.
