OK, so I verified my manual (94 XLT). On pages 322-323, the fuses are listed with a diagram. (On page 324, there is a different list that is specific for Limited edition, but 4 and 5 are the same in terms of turn signals, etc.)
OK, here you go:
Fuse #4: 15 Amp: Stoplights, 4-way Flasher
Fuse #5: 15 Amp: Back-up lamps, DRL module, Rear defrost control, Turn indicator, Turn lamps
There are no other fuses listed that affect the turn signals.
BTW, the difference between the Chilton's diagram (autozone) and Ford may just be the numbering of the fuses, since the Ford manual lists 4 and 5 as 15 Amps, while the Chilton's does not.
If you got the fuse number from the fuse panel itself, I would use the Ford diagram. Again, this info is for a 94, not sure if they changed it from 93 to 94.
I think you confirmed this in one of the messages above.
Now, what is the cause? If you have DRL (mine doesn't), and if there is a way to disconnect the DRL, that might be the place to start. Everything else on #5 "should" be turned off manually before you start the truck, assuming you don't have a short somewhere.
Let us know how it works out!
Mike
