Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
ranger rear end swap
Reply
Thread Tools
Old 10-24-2007, 09:53 PM   #1
xtream
bonney lake, wa
1998 ford ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Will a 1999 4wd rear end with a tag no. S333S 4L 10 88 8J10, interchange in a 98 ranger XLT 2wd, 4.0L automatic with a rear end no. S338M 3 55 88 8C25. & If so how would It affect the speadometer & fuel economy. Thanks. RYAN.
xtream is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-24-2007, 10:03 PM   #2
jimbo74
Elite Ranger
Nor*Cal
jimbo74's Avatar
98 XLT Supercab 4x2
Vehicle Specs
Quoted: 0 Post(s)
physically it iwill, but it looks like you are going from a 3.55 open rear end to a 4.10 limited slip
__________________
My Truck
jimbo74 is offline   Reply With Quote
Old 10-24-2007, 10:03 PM   #3
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
is it off of a ranger? I will assume that is what your talking about.
4.10 gears are nice, I really like mine
I would say just compare the perches for the springs everything else should be the same since the rangers axles have not changed since the dawn of time or at least it seems that way
__________________
Rusty...
2001 Mounty 4x4 4.0 SOHC 4.10's 180K miles
Current Mods: replacement Engine, TT, Shackle, AAL, Tranny Cooler, Exhaust, Transgo, Air shocks, ATF Temp & PSI ga., Ext Tranny Filter, UD Pulley, E-Fan, BW EPC, Custom Bumper, Body Lift
manaen is offline   Reply With Quote
Old 10-24-2007, 10:10 PM   #4
90ranajo
The Little TJ that could
Not here nor there
90ranajo's Avatar
O|||||O
Vehicle Specs
Quoted: 2 Post(s)
Well, considering it will be going into a 2wd there won't be too much of a problem. However, your factory rear has 3.55 gears and the donor rear has 4.10s. You will see a marked increase in low end speed and torque, but your top end will and highway mileage will suffer do to the lower gearing. If you mostly do lower speed city driving or heavy towing you might see an improvement on mileage. If you want to swap these rear ends and still have correct speedometer readings you could always swap to oversized tires to regain factory like gearing, or program your ECM/PCM for the gearing change.
__________________
O|||||O
KG7MXH
90ranajo is offline   Reply With Quote
Old 10-25-2007, 06:16 AM   #5
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Sorry but this is not correct.
98~2000 Rangers take the VSS from the rear axle ABS speed sensor. Since the sensor reads ring gear RPM, there is no adjustment necessary for axle ratio changes. The speedo will read exactly the same with either axle.
On the other hand, a tire diameter change does require an adjustment in the GEM or 4WABS Module to correct the speedometer for 98~00 Rangers. You cannot make any speedometer corrections in the PCM on Rangers before 2001.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
rwenzing is online now   Reply With Quote
Old 10-25-2007, 07:55 AM   #6
90ranajo
Not here nor there
90ranajo's Avatar
O|||||O
Vehicle Specs
Quoted: 2 Post(s)
See I do learn something new everyday.
__________________
O|||||O
KG7MXH
Old 10-25-2007, 11:46 PM   #7
xtream
bonney lake, wa
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thank you for the great advice and i did learn something new too.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
