#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How to: Replace a thermostat on a 1996 4.0L OHV V6.
Reply
Thread Tools
Old 11-17-2007, 09:49 PM   #1
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well, after replacing my thermostat I decided to do a write up on it. If you are needing to replace your thermostat, I highly recommend doing it yourself. It is easy to do, and very cheap.
Note: This is for the 4.0 OHV, not SOHC
First, a general disclaimer: I am not a Ford engineer, and do not work for Ford. Anything that you do, you do at your own risk.
Now to start. It should take about an hour to complete this, but giving yourself plenty of time is the first step. The tools I used are very common, and can be found just about anywhere.
Before you start, drain all of your coolant out of the car. This will make your life a lot easier down the road.
Tools used:
3/8" Drive ratchet
3/8" 2" drive extender
3/8" to 1/4" drive reducer
1/4" drive ratchet
10mm socket
8mm socket
Flathead screwdriver (not pictured)
Parts needed: Thermostat
New coolant
Now, where is the thermostat located?
It is on the end of the hose going to both the engine block and the radiator. It is where the hose bolts onto the block.
First off: The intake needs to go. Take off the latch for the filter, unplug the 2 plugs in the intake, and pull the vacuum line out. Now, unscrew the hose clamp with the flathead screwdriver, and remove intake.
Now there is that throttle cable cover there. That needs to be removed. Take you 8mm socket, and remove the 2 bolts holding that on.
After that is removed, remove the 3 bolts holding the hose on. These use the 10mm socket. It will take some experimentation with the different extenders/ratchets I have listed, but it can be done with just that. When you are loosening up the bolts and removing the hose, be prepared for coolant to leak from there. Have something underneath the front of the truck to catch it, Either an oil change pan or just some old towels.
Once removed, you will see this:
Please note that the thermostat shown in this picture is actually the new one, yours will not look that nice. It will also be wedged in there solid, and take some wiggling to remove.
When you place in the new one, be sure it is aligned the same way, and rotated the same way as the last one.
Now, put the hose back, and tighten in the 3 bolts. Then re-attach the throttle cable cover. Now put the intake back on. Be sure to re-attach both sensor plugs, and also the vacuum line.
Now, refill the coolant and burp the system.
You have now successfully changed your thermostat. Take it for a drive, then check for any leaks.
This is the old thermostat. Note how the gasket around it is worn and chipping.
Just remember, replacing your thermostat is easy to do yourself, and a lot cheaper too. Just take your time, and everything should go fine! If I have left anything out that you think should be added, be sure to add it or let me know!
__________________
Link to lift and max tire size info
1996 Sport
2000 XLT
1995 F-150
1987 F-150 XLT "The General"
Charlie is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-18-2007, 02:39 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the write up! I'm sure that it will help a lot of people out.
BrooklynBay is online now   Reply With Quote
Old 11-18-2007, 02:42 AM   #3
Burns
Pulaski, TN
Burns's Avatar
1991 Explorer/2002 F-250
Vehicle Specs
Quoted: 20 Post(s)
Great job man. Nice write up.
__________________
Jonathan Burns
Moderator of the Feature Truck Forum
Owner of the "Lime"
Forum Rules and Usage
Burns is offline   Reply With Quote
Old 11-20-2007, 11:26 AM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
Good write-up. Note that it's for an OHV, not an SOHC motor.
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 11-20-2007, 11:31 AM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Maybe a moderator could add OHV into the title?
Old 11-20-2007, 11:33 AM   #6
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks, just added it on.
Quote:
Yeah, I just looked to see if there was some way to edit it, but couldn't.
Moderator help would be appreciated here.
__________________
1996 Sport
2000 XLT
1995 F-150
Old 11-20-2007, 11:44 AM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Send a moderator a PM.
Old 11-20-2007, 11:48 AM   #8
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
You're a thinker!
__________________
1996 Sport
2000 XLT
1995 F-150
Old 11-22-2007, 10:26 AM   #9
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quoted: 20 Post(s)
A 10mm gear ratchet socket (hollow socket for removing long studs) fit perfectly to remove the bolt behind the idler. You can probably use something else but that very short socket got it off in one shot. If you have this set its worth a try.
Also, be sure the replacement stat is OEM or has a bleed hole. This helps purge the air when you refill coolant. Also, if your temp gauge is flaky a thermostat and the one wire sender will fix the issue.
96eb96 is offline   Reply With Quote
Old 01-11-2008, 03:04 AM   #10
Andy96XLT
Branchburg NJ, Bethlehem PA
96 XLT
Vehicle Specs
Quoted: 1 Post(s)
im sorry i know this is an old thread but what does it mean to "burp" the system? Also sorry for the probably dumb questions, but how do you drain the coolant? im not really an engine guy haha.
Andy96XLT is offline   Reply With Quote
Old 01-11-2008, 03:13 AM   #11
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
http://www.explorerforum.com/forums/...d.php?t=190060
Answers a few ways to burp the system
http://www.explorerforum.com/forums/...d.php?t=162848
Good thread on flushing system
__________________
1996 Sport
2000 XLT
1995 F-150
Old 01-11-2008, 08:48 AM   #12
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quoted: 20 Post(s)
Quote:
Here is the official procedure from the Ford manual. If you have 4.0L OHV engine be sure to follow this procedure to get out all the air. It is also in your owners manual!
WARNING: NEVER REMOVE THE RADIATOR CAP UNDER ANY CONDITIONS WHILE THE ENGINE IS OPERATING. FAILURE TO FOLLOW THIS INSTRUCTION COULD RESULT IN DAMAGE TO THE COOLING SYSTEM OR ENGINE AND/OR PERSONAL INJURY. USE EXTREME CARE WHEN REMOVING THE RADIATOR CAP FROM A HOT RADIATOR. IF POSSIBLE, WAIT UNTIL ENGINE HAS COOLED, THEN WRAP A THICK CLOTH AROUND THE RADIATOR CAP AND TURN IT SLOWLY TO THE FIRST STOP. STEP BACK WHILE THE PRESSURE IS RELEASED FROM THE COOLING SYSTEM. WHEN YOU ARE SURE ALL THE PRESSURE HAS BEEN RELEASED, PRESS DOWN ON THE RADIATOR CAP (STILL USING A CLOTH), TURN AND REMOVE IT.
Draining
Shut off engine (6007) and allow to cool.
Remove the radiator cap (8100). Refer to above warning.
Attach a 9.5mm (3/8-inch) inside diameter hose on the radiator draincock (8115) to minimize loss of coolant when draining. (look under your radiator - passenger side)
Open radiator draincock and permit coolant to drain into a clean container. (spray a bit of PB on it, then unscrew it)
Remove drain plug on cylinder block (6010) to allow coolant to drain from engine, if necessary. (not needed)
Dispose of old coolant properly. Promptly clean up any spilled coolant.
At this point you may want to flush the system, there are many ways. You can use a kit.
I like disconnecting the heater hose at the heater control valve, and inserting a push connect garden fitting into both hoses with the clamp(one is a drain or can be blocked off and another part open (e.g. rad cap)). Make sure the hose isn't on full blast(1/4-1/2 is fine since the heater core is fragile). You can flush a variety of ways (heater core, block, radiator) depending on the hose configuration.
Filling
WARNING: USE CAUTION WHEN ADDING COOLANT MIXTURE TO RADIATOR TO AVOID HOT COOLANT OR STEAM BLOW OUT FROM THE RADIATOR.
NOTE: Use the following steps to remove air from the cooling system and to make sure fill is complete. (VERY IMPORTANT FOR THE 4.0L)
NOTE: When filling a crossflow radiator (8005), allow time for the coolant to flow through the radiator tubes to fill both tanks.
Close radiator draincock and install cylinder block drain plug.
Fill the cooling system with a 50/50 ethylene glycol and water mixture. Allow several minutes for trapped air to escape (bubble out) and for coolant mixture to flow through the radiator.
Install radiator cap to pressure relief position by installing radiator cap to fully installed position and then backing off to first stop. This will allow any air to escape, and minimize spillage.
Slide heater temperature and mode selection levers to maximum heat position.
Start engine and run at fast idle (approximately 2000 rpm) for three to four minutes. Shut engine off.
With engine off, wrap radiator cap with a thick cloth, carefully remove radiator cap and add coolant to bring coolant level up to filler neck seat.
Replace radiator cap to fully installed position. Then, back off to first stop. Operate engine at fast idle until the upper radiator hose (8260) is warm (water thermostat (8575) opens). To check radiator, shut engine off, wrap radiator cap with thick cloth and carefully remove radiator cap. Add coolant if necessary. Replace radiator cap to fully installed position.
Open the small cap on the top of the radiator coolant recovery reservoir. The large cap is for the windshield washer reservoir. NEVER put coolant mixture in windshield washer bottle.
Using a suitable suction gun, remove all coolant from radiator coolant recovery reservoir.
Add 1 liter (1.1 quarts) of 50/50 mixture of ethylene glycol and water to the radiator coolant recovery reservoir. Close the small cap. (or fill between the hot and cold marks - suction gun is optional)
Also, check the level after a few trips. The OHV may need a bit extra coolant because of air issues.
Old 02-11-2008, 11:22 AM   #13
zims666
Chapel Hill, NC
99 XLS
Vehicle Specs
Quoted: 0 Post(s)
i had a problem with my engine overheating. i followed your guide step by step on replacing the thermostat and it, well, again -- i had a problem...
thanks for the info charlie.
zims666 is offline   Reply With Quote
Old 02-11-2008, 11:59 AM   #14
cybergasm
B
Humboldt Ks
cybergasm's Avatar
1997 Mountaineer 5.0
Vehicle Specs
Quoted: 0 Post(s)
Charlie you did clean up the gasket surface and used a new gasket right?
cybergasm is offline   Reply With Quote
Old 02-11-2008, 12:29 PM   #15
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thermostat has a built in gasket, so there is no gasket needed.
__________________
1996 Sport
2000 XLT
1995 F-150
Old 02-14-2008, 02:06 PM   #16
GRNMACHINE
IL
GRNMACHINE's Avatar
95 Sport 4x4
Vehicle Specs
Quoted: 35 Post(s)
Great Write Up! Just purchased a Stant SuperStat 195 degree Thermostat p/n 59369 for $7.99, the kid at auto store said to get a Rubber Water Outlet Gasket as well. Anyone have any recommendations on other brands i.e. Hypertech 180 degree t-stat, Beck Arnley etc. The Stant is made in USA with a lifetime warr. They also sold a "Motorcraft" t-stat for $21.99 but I find it hard to believe there would be much difference for the added money. Plan on installing it in the next couple of weeks when it gets a little warmer. Anyone want to share their 2cents would be appreciated.
Thanks, Rick
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 02-14-2008, 02:27 PM   #17
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Quoted: 10 Post(s)
Don't use the rubber gasket IMHO. I'd use a regular ol' paper gasket with some RTV. It was good enough to never leak from the factory, right? Rubber gaskets never seem to hold up for me. Paper with the proper gasket sealant has never let me down.
-Joe
__________________
Old 02-14-2008, 11:18 PM   #18
mikesparky
WPB, FL / Southern Pines, NC
95 sport OHV
Vehicle Specs
Quoted: 0 Post(s)
Great write up. It made me finally get off my arse and replace my thermostat.
"Before you start, drain all of your coolant out of the car. This will make your life a lot easier down the road." Pay attention to that part! I didn't and and watched a good portion of my coolant pour out when I removed the old thermostat. duh!
__________________
KKM Intake, 70 series flowmaster with custom 2.5" pipes... trying to afford gas. =]
www.mikesparksmusic.com
mikesparky is offline   Reply With Quote
Old 02-16-2008, 05:54 PM   #19
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
I just changed mine , I had no idea anything was wrong until I got a scantool and realized it was operating 20 c less than it should be. I changed the thermostant and the problem was fixed and the heat starting working much better
__________________
'96 XLT 4DR <<< RETIRED
'00 Sport 2DR
Signature modified by Moderator
G-96XLT is offline   Reply With Quote
Old 03-17-2008, 12:35 PM   #20
mshuler009
Centerville, Ohio
1998 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Seems like a lot of explorers have thermostats that get stuck open, just from reading on here......and I'm the newest one...lol
__________________
'98 4.0 OHV Explorer
Ford Certified Technician
NASCAR Technical Institute Alumni
mshuler009 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
