#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
A/C compressor thump?
Reply
Thread Tools
Old 03-11-2008, 05:31 PM   #1
ramblinwreck
St. Simons Island, GA
'06 Eddie Bauer V8 w/ NAV
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have noticed that there is a very pronounced "thump" coming from the front passenger side of my 06. It appears to be the A/C compressor engaging but I may be wrong. Has anyone else noticed this and should it be cause for concern?
ramblinwreck is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-11-2008, 07:46 PM   #2
steve6534
Southern NJ
'06 EB V8
Vehicle Specs
Quoted: 9 Post(s)
Quote:
I heard the same sound but haven't tried to isolate it yet.. Does it only occasionally happen when you first start the truck up ?
steve6534 is online now   Reply With Quote
Old 03-11-2008, 09:11 PM   #3
michael loibl
maywood, new jersey
2006 eddie bauer
Vehicle Specs
Quoted: 18 Post(s)
I can hear my ac cycle, but I wouldn't call mine a thump...that is too severe (for mine). My 2001 Honda is much more noticeable.
Does the noise occur only in an AC mode, and if so, how often ( once every minute or two?) I would put it on Ac and the lowest fan speed, then open the hood and watch the center of the AC compressor pulley to see if the noise is at the same time as engagement.
michael loibl is online now   Reply With Quote
Old 03-18-2008, 09:35 AM   #4
cwescapexlt4x4
Explorin' the Desert SW
Litchfield Park, AZ area
cwescapexlt4x4's Avatar
2016 Explorer LTD (FWD)
Vehicle Specs
Quoted: 147 Post(s)
Occasionally i have heard this as well, more so after starting the engine
__________________
16 Limited FWD Magnetic 301A, LED fogs, Tow, Adaptive CC & Collision Warning Brake Support, 2nd Row Bucket Seats (center console), LED Puddle Lamps (Daytime Brightlights), LED reverse, turn (F/R), plate, Husky Mats.
2013 VW Jetta Sportwagen TDI Gone -2013 Explorer XLT / 2011 Kia Optima SX-T / 2006 Explorer EB 4x4 V8 / 2011 VW JSW TDI / 2001 Escape XLT 4x4 V6 / 2001 Focus SE Wagon
cwescapexlt4x4 is offline   Reply With Quote
Old 03-31-2008, 08:24 AM   #5
apuntsel
Pittsburgh, PA
apuntsel's Avatar
2006 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I have had the same issue and it was taken care of at the dealer. Here is the TSB for the problem -
TSB
07-19-7 A/C COMPRESSOR THUMP NOISE - 4.6L
Publication Date: September 11, 2007
FORD: 2006-2008 Explorer
2007-2008 Explorer Sport Trac
MERCURY: 2006-2008 Mountaineer
This article supersedes TSB 07-12-7 to update the vehicle model years.
ISSUE:
Some 2006-2008 Explorer 4dr, Mountaineer and 2007-2008 Explorer Sport Trac vehicles equipped with a 4.6L engine may exhibit an intermittent thump or similarly described noise transmitted into the passenger compartment in A/C / Auto / Defrost modes, when the A/C compressor engages.
ACTION:
Follow Workshop Manual, Section 412-01 to replace the A/C suction accumulator and O-rings associated with the repair.
NOTE: A/C COMPRESSORS SHOULD NOT BE REPLACED FOR THIS CONDITION.
NOTE: THIS ACCUMULATOR SHOULD ONLY BE USED TO SERVICE THIS SYMPTOM. DO NOT USE FOR NORMAL A/C REPAIRS.
PART NUMBER PART NAME
6L2Z-19C836-B A/C Accumulator
1W1Z-19E889-LB A/C O-Ring
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071907A 2006-2008 Explorer/Mountaineer, 2007-2008 Explorer Sport Trac 4.6L: Replace The Air Conditioning Suction Accumulator, Includes Time To Recover, Evacuate, And Charge The Air Conditioning System (Do Not Use With 19700A, 19700A18, 12650D6, 9600A) 1.0 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
19c836 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright 2007 Ford Motor Company
__________________
2006 Ford Explorer Eddie Bauer
apuntsel is offline   Reply With Quote
Old 04-01-2008, 12:49 PM   #6
ramblinwreck
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
TSB
ISSUE:
ACTION:
WARRANTY STATUS:
DEALER CODING
19c836 42
Man that's great. Thanks for sending me this info. I'm calling to set up an appointment today.
Old 04-06-2008, 11:32 AM   #7
rpr
Smith Mountain Lake, VA
2006 Limited
Vehicle Specs
Quoted: 0 Post(s)
Thanks! My dealer previously told me this is "normal".
rpr is offline   Reply With Quote
Old 04-16-2008, 03:18 AM   #8
Essex4x4
Johnston Iowa
2011 Dodge Grand Caravan
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Talked to my dealer because i keep hearing the thump from the A/C and they said that it was "normal and not to worry," they also told me that if i have a problem and it breaks its covered under the warranty.
__________________
James
The Swagger Wagon
http://youtu.be/ql-N3F1FhW4
Fuel economy, cargo and family fun power... yep I bought a minivan Love it!!
Essex4x4 is offline   Reply With Quote
Old 06-18-2009, 07:00 PM   #9
tekim269
npr,fl
`95 ranger xlt
Vehicle Specs
Quoted: 0 Post(s)
my 95 ranger thumps too
1995 ranger xlt - I have heard this loud "thump" coming from my passenger side also usually within a few seconds after I switch on the A/C. It sure makes you look over there ...sounds like you were hit by something.
Well I have had my truck for 10 years and have heard this " thump " for most of those years -- only on occasion not always ...but until recently it has been happening more often. It does not sound " normal " but it has been doing it for years and my A/C works fine.
i`m not a mechanic but it does like something pressuring up and thumps. lol
mike
tekim269 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
