entoptics
- November 8, 2007
- Pac NW
- 2000 XLT SOHC
Finally installed some Air Lift helper suspension. My first impressions are good.
The kit was very well stocked and had good vehicle specific instructions. The install was pretty straightforward with the only "tricky" part being drilling a total of six 5/16" holes in the frame for the self tapping upper mounting bolts. After removing the wheels, all work was easily done with almost no need to get under the vehicle.
I haven't tried it under load yet, but with the minimum suggested 10 psi, it raises the rear ~1/2" and doesn't discernibly affect the ride quality.
I installed it to assist when fully loaded for camping and carrying my motorcycle on a hitch rack I built (~375 lbs total tongue weight, 8" rearward of bumper plus another ~600 lbs of gear in the cabin).
Here's why I need it. Notice the 2" of fender to tire clearance.
I made some animated gifs showing 0, 13, 40, and 80 psi. Soda can for scale.
Some pictures of the install and one side of the air line routing. I used some pre-existing big holes in the bumper and some small ID/Big OD washers to sandwich the valve stems in.
Tips for installation. You want to make sure the brake line retaining bolts (red arrow) have been thoroughly lubed. I sprayed WD-40 on them several times in the 24 hours preceding the install. Also, jack the leaf spring up to normal ride height and then drill the holes for the air spring with it inserted perpendicular to the surface of the leaf. It won't be directly up and down.
Thanks for the suggestions awhile back. Great forum.
