00_Green
- February 22, 2009
- atlanta & memphis
Truck Won't Move In Forward Or Reverse - Finally Disassembled
1994 model purchased a year ago w/130k. The tranny at the time had sluggish shifting and harsh rev engagement when cold. There was no metal in the pan at that time, just the typical gray sludgy stuff one would expect to see. I installed a shift kit, changed the servos, modulator, filter, and fluid. The transmission had been perfect since.
Last night my daughter calls, She said "it stalled as she was coasting to a stop. It restarted but the engine stalled everytime she tried to put it in Rev or OD. She kept messing with it and it stopped stalling but wouldn't move forward or reverse in any gear".
I brought it home this morning, it was almost 2 qts low on fluid. The fluid is red, clear & clean, and smells like new. The pan gasket may be leaking a little, nothing seems to be comming from the front seal.
I've topped the fluid, When I put the shifter in any gear you can feel what I can only call engagement but the truck wont move as it should. Stepping on the gas the vehicle trys to move and actually will move a little if you really rev it up but the transmission seems to be not really engaged or it's slipping.
Not being a tranny person and for a lack of better ideas instinct tells me to pull the pan and look for metal. If the pan is clean drop the valve body and look for who knows what. If thats all seems good pull the trans and change the TC?
Comments or suggestions? Are there any codes I should try to look for?
