rampage
- May 27, 2009
- Stroudsburg Pa
- 2000 sport 4.0 sohc
I have a 2000 explorer sport no rev. I droped the pan and had no metal in the fluid,just a little grey sediment. looking at the reverse sevo I saw the VB gasket blown out.removed and checked and cleaned VB,installed new gaskets re-assemble following torx spec and still no good. with the truck runing in park you can tell the park pin is loaded, reverse some forward movement, neutral it goes forward, drive forward ect.. It seems fluid is not flowing through the right valve someplace. any ideas would help.
