Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Burned out front signal bulb - not burned out
Reply
Thread Tools
Old 06-22-2009, 11:29 AM   #1
gsmaclean
Strongsville, OH
03 Limited
Vehicle Specs
(Original Poster)
While driving home last night, I realized that I had a burned out turn signal bulb - it was clicking about twice as fast as it should. I got home and saw that the rear right signal worked, but the front right signal did not. The parking lights (same bulb) worked fine. Strangely enough, the turn signal indicator on the dash did not light up as well, but I figured that's just how it worked in these trucks.
I pulled the light out and put a new bulb in. I tested it - still no turn signal. Uh oh. I tried another new bulb, just in case. Still no turn signal.
I tried swapping the left and right turn signal relays. Still no turn signal.
So I went inside, got my Haynes manual, and had a look at the schematic. The only failure mode that could cause this (no front turn signal, no internal signal indicator light) is a failure of the multi-function switch (the switch the left stalk is connected to - turn signals, high beams, windshield wipers, hazard lights, etc). According to the schematic, the hazards should still work in this failure mode. So I went outside to try - and sure enough, all four bulbs lit up with the hazard lights.
I found a new OEM replacement switch online - the cheapest vendor I found was actually amazon.com - for $56.
So...if you have a front turn signal that stops working, and the dashboard turn signal indicator also stops working - BUT the four-way hazards still work, then get ready to replace your multi-function switch.
gsmaclean is offline   Reply With Quote
Old 06-22-2009, 11:31 AM   #2
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Good tip gsmaclean, thanks!
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
Ford Explorer and Ranger Owner's Guides and more...
fixxxer is offline   Reply With Quote
Old 06-22-2009, 01:22 PM   #3
Fox Fader
Columbus, GA
searching
Vehicle Specs
Even the Gen 3 multi-function switch craps out. More to look forward to.
__________________
_______________
2005 XLS 115k not even side steps (sold)
2001 Sport-Trac 131k Wife's
Fox Fader is offline   Reply With Quote
Old 07-01-2009, 04:17 PM   #4
gsmaclean
Strongsville, OH
03 Limited
Vehicle Specs
(Original Poster)
I was right - I popped the replacement switch into the steering column last night, everything now works perfectly again. A quick 15 minute repair job, all you need is a philips head screwdriver.
Old 07-01-2009, 04:19 PM   #5
gsmaclean
Strongsville, OH
03 Limited
Vehicle Specs
(Original Poster)
By the way, this is the switch I bought and installed.
Old 07-01-2009, 04:56 PM   #6
Fox Fader
Columbus, GA
searching
Vehicle Specs
Thanks for replying back with the fix confirmation.
__________________
_______________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
