Freshmeat
- July 26, 2008
- Denham Springs, LA
- 1994 Ranger STX SC
I figure I'll just do this so I can track my own motions and make sure I cover everything. Any input would be greatly appreciated.
Here's a list of what I've gathered so far:
M5OD and related wiring from 1990 Mazda Navajo
ECM from 1990 Mazda Navajo
Starter from 1990 Mazda Navajo
Pedal assembly (complete)
New Master cylinder
New Slave cylinder
New Pilot bushing
New Throwout bearing
New Clutch kit (Valeo)
New Flywheel
Floor plate
Shifter assembly
I went to replace the three rubber plugs on the back of the transmission, but they've already been replaced by the Dorman metal plugs, so that saves me a few minutes.
First step (tonight) is to swap the pedal assembly. Almost every conversion I read said the pedal assembly is the hard part, so I'm going to knock that out tonight so I won't have to spend most of my Saturday fighting to get it swapped out. If I have time left tonight I'll probably just rebuild a window motor or two. I don't want to start pulling a transmission only to not get back to it for a few days.
I guess I'll go get started. This was supposed to be a reasonable mode of procrastination but it didn't take as long as I'd hoped.
New Master cylinder
New Slave cylinder
New Pilot bushing
New Flywheel
Floor plate
Shifter assembly
