Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
RABS bypass
Reply
Thread Tools
Old 10-20-2009, 08:27 PM   #1
wolfeman
Travelers Rest South Carolina
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
RABS bypass
Hello,
I was wondering for those of you who have bypassed the Rabs module. is there a proportioning valve some whereelse or is the rabs the proportioning valve. do your brake "feel" different after you bypassed the module. I am interested in this because i have a high miler that i dont want to spend alot of money on but it is my daily driver right now. thanks for any info
wolfeman is offline   Reply With Quote
Old 10-20-2009, 09:17 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
What kind of problem do you have with the RABS brakes?
BrooklynBay is offline   Reply With Quote
Old 10-21-2009, 06:57 AM   #3
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
rabs
hello,
my rabs valve leaks out the small hole on the end when the brakes are applied.
Old 10-21-2009, 09:07 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Autozone sells this part for $150 with a lifetime warranty.
Old 10-21-2009, 02:38 PM   #5
YBCold
702 LΛ§ V£GΛ§ NV / МØΠΤΣΓΓΣΨ ΜΧ
91 ×∟┬
Vehicle Specs
hm. my module is leaking i think . there is a small hole init that look like its leaking and it tends to pool around the fuel filter
__________________
http://www.youtube.com/user/unaffiliatedperson
---)()(MUGSHOT()(---
All I wanted was a pepsi, just one pepsi! and she wouldnt give it to me just a pepsi!
YBCold is offline   Reply With Quote
Old 10-21-2009, 04:07 PM   #6
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
autozone part
hello,
i have read on here that the autozone part has issues with the threads not being the same as the lines. anyone use this part with no problems?
Old 10-21-2009, 04:12 PM   #7
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
ybcold
that is where mine is leaking too
Old 10-24-2009, 09:22 PM   #8
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
i guess no one has replaced their RABS valve with the autozone part.
Old 10-24-2009, 09:24 PM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
I bought the Autozone part, but didn't get a chance to install it.
Old 10-29-2009, 09:04 PM   #10
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
anyone???
Old 10-29-2009, 10:09 PM   #11
Foxracin
Mount Holly, NC
1991
Vehicle Specs
Junkyard?
Foxracin is offline   Reply With Quote
Old 10-30-2009, 09:55 PM   #12
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
i am afraid that a junkyard part will give the same problem. i dont mind buying the autozone part but i dont want to get the lines apart and find out that the the part isnt a good fit. i searched on here and found 2 guys that were having problems with the AZ part. that is why i am hesitant.
Old 11-05-2009, 05:58 PM   #13
wolfeman
1996 4.0l 4dr 4wd
Vehicle Specs
(Original Poster)
anyone use the autozone rabs valve with success????
Old 11-06-2009, 12:23 AM   #14
YBCold
91 ×∟┬
Vehicle Specs
heres the thing im talking about. would really love info on how to fix this. should be easy
__________________
Old 11-08-2009, 11:34 AM   #15
YBCold
91 ×∟┬
Vehicle Specs
wolfeman have you had any success with this yet?
__________________
Old 11-08-2009, 11:39 AM   #16
90ranajo
Not here nor there
90ranajo's Avatar
R15X
Vehicle Specs
If you want to bypass it, go down to the parts store and pick up a union to connect the input and output lines together.
I had some issues with my RABS causing a soft spongy pedal that would slowly drift to the floor when pedal pressure was applied and held. After some researched, I found that the RABS module had a tendency to start rusting on the interior and give me the symptoms I was seeing. After bypassing it and bleeding the brakes, my pedal became nice and firm and wouldn't push to the floor any more. I also noticed that the truck didn't want to push through the brakes anymore.
__________________
R15X - less stock then RockRanger's, and way less dented than DB1's ranger.
Quote:
Originally Posted by Paul View Post
Just understand, I'd rather roll off the edge of the cliff than drag a body panel agianst the rock wall...
90ranajo is offline   Reply With Quote
Old 11-08-2009, 04:22 PM   #17
92exp4x4
Covington, Kentucky
92exp4x4's Avatar
92 XL 2-door and others
Vehicle Specs
I have a 90 Bronco full size that I bypassed the valve on. Its the same system. I Never have had any trouble out of doing it, i don't drive crazy enough to need it anyway. I never have liked ABS. I nearly wrecked because of it actually.
__________________
My stable:
2 doors - '91 Eddie Bauer; '92 XL 5 speed; '92 Sport 2WD 5 speed
4 doors - '91 XLT; '93 XLT; '94 XLT, 6" lift, 33's; '94 Eddie Bauer 5 speed; '94 Limited
Others - '22 Model T, '48 8N tractor, '62 Fairlane 500, '93 F-Superduty 460, '97 F250 Powerstroke, '04 F550 service truck (company owned)
92exp4x4 is offline   Reply With Quote
Old 11-08-2009, 06:21 PM   #18
KobeJ05
Marina, CA
1994 explorer 157k miles
Vehicle Specs
i dont have a rabs i just have a black box in that spot with a wire pluged in it
KobeJ05 is offline   Reply With Quote
Old 11-09-2009, 08:13 AM   #19
Lynnrb
Phoeniz, Az
'92 XLT
Vehicle Specs
rabs reman unit
Quote:
The Rabs remanufactured unit i tried leaked at the brake line fittings. I returned it. Might have been Autozone. Got one at the dealer $250+, can not remember. They only had new ones but would not sell it until I gave them the old one. Did not get a core refund! Go figure.
Lynnrb is offline   Reply With Quote
Old 11-21-2009, 02:55 PM   #20
YBCold
91 ×∟┬
Vehicle Specs
right now im working on a write up of how to remove this thing. but my brake lines bolts are siezed at the HCU. i grabbed two bottle caps and filled them PB Blaster and i will let them sit over night and soak in the stuff. and see how easy they are to remove tomorrow.
i also considered cutting the line out but im not sure if they are expensive to replace. do they have any kind of pressure gradient to them? are they preformed?
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
