backshot
- August 13, 2015
- SE Ohio
- 93 explorer Eddie Bauer
I have a 1993 EB explorer & need to bypass the ABS/pump/HCU. It does have abs sensors on the front wheels & the HCU is leaking fluid. I can't find a new or used HCU & never liked the ABS on this vehicle to start with. How do I go about bypassing this unit? Is there a proportioning valve in this system or can I just use a "T" fitting to connect both front calipers together? Or can I use a proportioning valve from a non-ABS Explorer? Any suggestions or help would be greatly appreciated. I plan on replacing all the brake lines with NicCop when I do this. Thanks!
