#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Oil pressure gauge shows no oil pressure!!
Reply
Thread Tools
Old 11-17-2009, 05:10 PM   #1
black974X4
Louisville, KY
1997 sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've had my 97 explorer for about 3 weeks now and when I first bought it i noticed the temp gauge didn't work correctly. Had plenty of coolant and thermostat was opening and closing fine. About a week later i noticed the oil pressure gauge bounces sometimes randomly. Well here is the big problem. I started my car after classes today and it showed i had pressure, then while driving i noticed it showed i had very low pressure and the needle was bouncing a lot. Then it went to zero. The car still runs great, no metal to metal sound, no smoke, nothing. Could i have a bad instrument cluster or bad oil pressure sending unit?
car has 142k miles on it.
did an oil change 2 weeks ago, and it has plenty of oil in it with the problem
Thanks for any help!!
black974X4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-17-2009, 05:42 PM   #2
Blazepet7
Queens, NYC
99' XLT 5.0
Vehicle Specs
Quoted: 0 Post(s)
Welcome...Mine dosent fluctuate while driving but when I cold start my ex it stays pinned on no pressure there is a thread on how to replace the pressure sensor it is a cheap sensor and is real easy to change if the truck has that many miles it dosent hurt to change it again I don't have any info on the fluctuation...but I know a bunch of guys have this problem...good luck try the search button or go to the forums page it WILL help, hope this helps
__________________
99' 5.0 V8 XLT-FORD Red, Hella 500 Fogs,Pioneer AVIC D1 Navi, Sony DVD Player,TT/Shackles, AAL, Custom Rack lights, Rancho 5000's, LED Puddles, Custom Front Tow Hooks Many More Mods to Come
Blazepet7 is offline   Reply With Quote
Old 11-18-2009, 11:38 AM   #3
jid
2001 Sport
Vehicle Specs
Quoted: 0 Post(s)
I have a 2001 Sport that does this. But only in the morning. I changed the oil to fully synthentic. now it takes 45 seconds for the pressure gauge to come up to normal in the morning. But only in the morning. I'm going to replace the sender and i don't hear any knocking. but yes, i'm concerned...
jid is offline   Reply With Quote
Old 11-18-2009, 11:43 AM   #4
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
Quote:
Either one is possible, you'll have to do some trouble shooting.
If it was mechanical, a real loss of oil pressure, you'd have known it immediately.
It could be something as simple as corrosion at the sensors electrical connection. Simply verify that both sensors connectors are in good shape. Clean them with electrical contact cleaner or just use some brake cleaner.
my98nnj is offline   Reply With Quote
Old 11-18-2009, 12:05 PM   #5
CobraSix
Massachusetts
1991 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
I never did figure out why my oil pressure gauge in my 91 is all screwy. After the car warms up, oil pressure goes to 0. I replaced the sender, same. Check with a mechanical gauge, sure enough, pressure is 0 at idle, 35psi at 1500RPM.
Been doing that for 70k miles now, engine still purrs, doesn't burn oil, no lifter ticking...but no pressure at idle. Also the time it takes for it 'lose' pressure varies based on outside temperature and oil weight used. If it is cold outside, it takes longer to lose pressure and it returns to full pressure at a lower RPM. If i use 10w30, it losses pressure at a lower RPM than using 20w50.
__________________
Slade & The KaStang
1965 Mustang Convertible
1991 Ford Exploder
1998 Volvo S70 T5
1999 Mustang Convertible
CobraSix is offline   Reply With Quote
Old 11-18-2009, 01:47 PM   #6
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
20w-50... Holy crap!!! Why are you running racing oil?!?
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 11-18-2009, 04:37 PM   #7
CobraSix
Massachusetts
1991 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
If I didn't...I'd lose oil pressure at 1200RPM. While I think it is some weird internal engine quirk, I don't like driving down the highway with no pressure. It's one thing to let it idle with no pressure, another to drive 70MPH with no pressure.
I actually usually put about half a quart of straight weight 80 in during the summer as well to keep the pressure up as low as 1000RPM. I have a magic formula based on seasons to keep the pressure up but still allow the car to crank.
Cut the engine some slack...325k miles, and they haven't been easy miles. Beach wheelin, off roading, mudding, Boston Traffic, SoCal Traffic, spent the first 100k miles as a commercial vehicle towing trailers.
And only had to rebuild the transmission once at 160k miles.
__________________
Slade & The KaStang
1991 Ford Exploder
1998 Volvo S70 T5
Old 11-18-2009, 07:56 PM   #8
black974X4
Louisville, KY
1997 sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for all the responses. I went to start it up today and it started fine and ran fine, but it still showed little to no oil pressure. I had to move it tonight for my dad to get out of the driveway and there was a slight tick(very soft tick), I don't know if this is common with these engines on very cold start ups(low 40s outside). I'll be getting the problem fixed this weekend, hopefully it isn't anything mechanical.
Old 11-18-2009, 10:59 PM   #9
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Right on CobraSix- it's stuff like yours that makes for great Ford stories!
OP- how is your oil level? When mine is low, I get a tick on startup...
__________________
Old 11-19-2009, 08:04 AM   #10
black974X4
Louisville, KY
1997 sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Oil level is great, drove again today to school, about 15 miles, and it ran fine. Still had a slight tick for the first few minutes after start up, but I didn't hear it when I got to school. Hopefully going tomorrow to make sure it has plenty of oil pressure.
Old 11-19-2009, 08:25 AM   #11
CobraSix
Massachusetts
1991 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
A tick on startup for up to 30 seconds isn't uncommon. Just means the lifters are pressurizing. If it happens a lot, it may be a sign of a lifter starting to wear out (they usually don't loss pressure every time you let it sit for long periods).
As it was previously said, if you really had lost true oil pressure, you'd know it very clearly within 5 minutes (max) as your explorer would become an exploder and come to a screeching halt.
I've thought about contacting Ford...
__________________
Slade & The KaStang
1991 Ford Exploder
1998 Volvo S70 T5
Old 11-19-2009, 08:55 AM   #12
Paints-n-cows
central Illinois
(2) '95 Explorer XLTs
Vehicle Specs
Quoted: 0 Post(s)
It was my understanding that these oil guages are strictly electrical. With your fluctuation, I would suspect a loose/corroded wire or just a malfunction within the sensor itself.
The "tick" could be just a normal valvetrain noise. If you are like me, when you think you have a problem, every little squeak or tick becomes the sound of the engine coming apart.
Paints-n-cows is offline   Reply With Quote
Old 11-19-2009, 11:04 AM   #13
black974X4
Louisville, KY
1997 sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks everyone! And paints n cows that's exactly how I am lol. It's driving fine so I guess it's just somethig eletrical. I'm getting it checked now as I type this.
Old 11-19-2009, 01:51 PM   #14
black974X4
Louisville, KY
1997 sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was leaking oil through my oil pressure switch. Also found out my upper control arms need to be replaced . Guess I'm doing that this weekend, oh fun!!
Old 11-19-2009, 08:26 PM   #15
NICE59FORDF100
Moderator Emeritus
Austin, TX
NICE59FORDF100's Avatar
OBD-1 Kenobi
Vehicle Specs
Quoted: 50 Post(s)
Don't mean to hijack, but I am in the same boat.
Just rebuilt the motor in my 92, and after the motor warms up, the gauge says I loose all oil pressure at idle (really anything under 1200 rpm). Replaced sender with one from 300 I6 to convert to real gauge, and its still showing I loose pressure. Only thing I know to do is to replace the gauge with a spare.
Any ideas?
Like I said, almost new internal motor (only things reused were connecting rods, crank, cam, and rocker arms/pushrods). All stock with stock clearances...
__________________
1992 Eddie Bauer 4.0 OHV+5R55E 4WD - "Blue Bandit"
1997 Limited 4.0 SOHC 4WD - "Shade Bandit"
1959 Ford F100 - "Sloopy Bandit"
2005 Ford Thunderbird - "Dion Bandit"
NICE59FORDF100 is online now   Reply With Quote
Old 11-21-2009, 12:29 AM   #16
994x4Bauer
Sapulpa ,OK
1999 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I am the same way with the noises. Mine has 82,000 miles , I got it when it had 75,000 on it and have already had to replace the upper control arm/ball joints, lower ball joints, sway bar links, (all MOOG parts)and I need to replace the oil pressure switch and see if that fixes my no pressure at cold start-up issue and have the exhaust replaced as it is so rattly noisy you cant hear yourself think!!!!
994x4Bauer is offline   Reply With Quote
Old 12-06-2009, 05:05 PM   #17
teaman5843
nj
2001 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
I had a problem with 2001 explorer sport oil pressure gauge not working when below 50 degrees. I thought it might be the gauge, the wiring, the pump clogged with slick 50, or anything else when I came to this site. I saw it was a common problem, replaced the sending unit, and it worked like a charm. Thanks all.
teaman5843 is offline   Reply With Quote
Old 01-12-2010, 07:23 PM   #18
joeward87
North East Arkansas
2000 XLS
Vehicle Specs
Quoted: 0 Post(s)
I have had this problem with mine, my fix is to go buy your self a can of seafoam. Pour half a can in your oil start the vehicle wait for oil pressure to pick up, let the vehicle warm up real good shut it off and let the oil drain for a good hour thin put new oil and filter.....just try it :P
joeward87 is offline   Reply With Quote
Old 08-18-2010, 12:25 AM   #19
mechomancer
Ada Oklahoma
1999 4.0 2wd EB
Vehicle Specs
Quoted: 0 Post(s)
Well i just finished replacing the frame and pulled motor and trans together unhooking nothing but the two large connections to body and fuel and stuff and put everything back in order when new frame went back under it. the oil pressure gauge is not working now. I know it worked before and stayed at 1/2 to 2/3 towards high most of the time now nothing still purrs and runs great aside from that code 37 from airbag but thinking this might be a grounding issue as well
Where on the 4.0 SOHC on the 99 is the sending unit??
BTW got the exhaust done and new battery put in since the changeover drove it to town and back with little prob
mechomancer is offline   Reply With Quote
Old 08-18-2010, 08:11 AM   #20
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
oil pressure switch location
The oil pressure switch screws into the left (driver) side of the block behind the power steering pump as shown below.
It has very limited access. You'll probably have to remove the wheel and inner fender flap for access.
2000StreetRod is online now   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
