vaprtrl
- January 3, 2010
- Akron, OH
- 2002 XLT
Hello,
I did a little searching on the forums, but can't quite find the same situation. I have a 2002 4.0L V6. When the weather turned cold this year, I noticed the engine temperature guage would not come up to the normal range, and I got a check engine light. I don't have the codes handy, but they were 1) O2 sensor bad, and 2) Engine coolant temperature always low. (I've driven it for several months this way - not sure if that makes a difference.) I recently replaced the O2 sensor, and that code went away.
Even though I get heat I replaced the thermostat, expecting that it was stuck open. I also made sure the coolant level was correct. The code remained. I measured the resistance of the ECT when the engine was cold (don't know the outside temperature, but it was really cold), and after I had run some errands. The resistance values were around 1,000 kOhm cold and around 4 kOhm hot. (Not quite where I expect based on the Dead Link Removed I've seen floating around the forums, but still close.)
(In the mean time, the engine frequently dies when I put the transmission in gear after starting the engine from a cold state. I generally let the engine warm up for 10-30 seconds, or longer if I have to scrape the snow. Not sure if this is related.)
The resistances seem reasonable, but since the sensor is so inexpensive ($12.99 from AutoZone), I picked one up today and replaced it. The problem is, the truck won't start with the new sensor.
I noticed that with the new sensor (engine cold - it's around 18 deg F here, not running), the temp guage looks like the engine is warmed up normally (about halfway across the operating range). So I'm thinking that the fuel system thinks the engine is warm, and it won't start because there is no "cold start" signal.
So I unplugged the sensor, and the engine started for me. After a few seconds, I stupidly (I think), plugged it back in. The engine died almost immediately. So I unplugged it again, but I can't get the truck to start. Then I plugged it back in to the old sensor (hanging in the air), and it still won't start.
So I have a few thoughts.
I'm starting to ramble, mostly because I'm really frustrated. The behavior of the ECT does not make sense to me. The long and the short of is that I have a three-week business trip coming up this weekend, and if I can't get this fixed, then my wife will be going bonkers stuck in the house with our toddler daughter in stupid Akron. So,
Thanks for any help you can provide.
Best wishes,
Alan
- The engine won't start again because it's so cold here, and I've flooded it with all this starting and stopping the engine. Can someone verify that this makes sense? It's so cold right now I don't want to pull the plugs to vent the cylinders if I'm mistaken.
- The new ECT sensor is not working correctly. Why else would it be showing a normal operating temperature when it is so cold?
- Maybe the original ECT was fine, and there is something else wrong. But this doesn't seem likely - new aftermarket parts generally work, right?
- Am I on the right track?
- What else should I be trying?
Best wishes,
Alan
