Right camshaft end
The following caption and photo was posted by CDW6212R:
"Okay, check out this picture of my engine just before I timed it. This picture below shows the right head camshaft end. Notice the two slots in the end of the cam. They are offset to the lower side. The special cam tool engages those and forces the cam to locate those two slots in parallel to the surface of the valve cover rail. Regards, Don"
Unfortunately, the cam bearing cap hides the cam lobes in the photo. It is possible to tighten the cam sprocket bolt 180 degrees off with the tool in alignment.
The following caption and photo was posted by tmh6202:
"Hey Don,
I think it is also worth mentioning that even though you use the tools, only one head can be done at a time. BUT, both the primary chain and front cassette have to be off/out at the same time as the left cassette chain is behind the primary chain. The biggest thing to make certain you do is to keep the cam sensor nub in the proper place in relation to the head. This can change even if you use the OTC6488 tool kit to hold the rear cam in place. The tension from the valve springs will cause the cam to rotate somewhat. I was victim of this during my rebuild. Got it back together, tunred it over, sounded ok but would not catch and run. We took the valve covers off and when compared to before pictures and diagrams, we realized that the flat spot was on the bottom of the cam, 180 degrees off. OOPS! It pays to take pictures and follow directions! The flat spot in the picture below is the opposite side of the cam that needs to be up at installation/tightening of the cassette to cam bolt. The opposite side has a flat spot with a nub that sticks up to "trip" the sensor. I cannot locate a photo of that, but I have not looked at everything I have yet. I will scan a diagram from the instructions tomorrow and post it for those who need it.
Good luck everyone! Mine is still running strong and QUIET!
Todd"
I've seen another photo of the lobes in the correct position but haven't been able to find it yet.
