Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How To: Fix the Door Ajar Problem
Reply
Thread Tools
Old 02-13-2010, 01:47 PM   #1
synyster
Hammond IN
'02 Limited V8
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
A few weeks ago I kept having a problem with my door ajar, rear defrost, and dome lights coming on and staying on when I would turn on my rear defrost. After weeks of looking on the internet I finally found the cause. Here is what I did to fix it. It turns out it was a broken wire in the door boot.
1. These were the tools and stuff I used to fix it. Yes the butter knife actually helped. I used: 1/4" Ratchet, 6" extension, 6mm 7mm and 8mm sockets, wire stripers, a butter knife, needle nose pliers, a screwdriver, electrical tape, and 12 AWG Industrial wiring from Menards.
2. Start by removing the door panel trim. There are 3 bolts. 2 on the bottom of the door and one when you remove the trim piece above the door handle. Slide the panel over the door handle and disconnect any connectors that are there. DON'T leave the panel hanging with the connectors because you run the risk of damaging them or the wiring going into them. I used a butter knife to get the mirror adjusting connector out because I didn't have a small enough screw driver.
3. Once you remove the trim panel there should be a boot that goes in between the door and the body of the truck. I used a 1/4 ratchet and a screwdriver to get it out. I used the screwdriver to get under the boot on the body side and jammed the ratchet in so I could take the screwdriver and move it around the boot to pop it out. Once you pop it out go threw the wiring and look for a 12 awg wire that is broke give it a few light tugs until it comes out.
4. This is the side of the wire coming out of the body of the truck. I used a single piece of stranded 12 awg industiral wire to jump across the break in the wire.
5. This was the side that was in the door. I took the other end of the 12 awg wire and spliced it to the end that was in the door. After that I checked it and the problem was solved. I finished up by wraping it in electrical tape. Don't mind the taping skills, this is just a temporary fix for right now until it gets warm enough for me to stay outside and solder and heatshrink it.
6. Another view of the repair.
synyster is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-03-2010, 09:58 PM   #2
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Great write up. The pics are nice!! I have been putting this off. I have seen a lot of good info on getting this done. Hopefully I get motivated soon and tackle this.
BigRondo is offline   Reply With Quote
Old 03-04-2010, 03:51 AM   #3
elcapitanmas
Coventry Ct
2002 xlt
Vehicle Specs
Quoted: 0 Post(s)
I just did mine a few days ago, I had a bad sensor rather than a wire break, but pretty much had to pull all the same parts. Was done in less than 20 minutes. great write up
elcapitanmas is offline   Reply With Quote
Old 03-07-2010, 10:14 PM   #4
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Got mine fixed today! It was the smaller of the 2 black ground wires. Good to have things back to normal.
Old 03-07-2010, 10:47 PM   #5
derfiticulum
Lincoln, NE
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
I just fixed mine, too. Fortunately mine was as simple as spraying wd-40 into my latches. I can't believe that I let the issue continue on and off for 3 or 4 years when the solution was so simple.
derfiticulum is offline   Reply With Quote
Old 03-08-2010, 09:44 PM   #6
synyster
Hammond IN
'02 Limited V8
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Quote:
LMAO 3 or 4 years and it didn't bother you........I had this problem for 2 weeks until it drove me crazy and I fixed it.
Old 03-08-2010, 10:09 PM   #7
derfiticulum
Lincoln, NE
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Oh, It bothered me. But it would only happen for about 5 or 10 minutes after getting in the car and then only when cold out. The event that broke the proverbial camel's back was when my dome lights wouldn't shut off long after the car was shut off. Did some quick research and found the wd-40 solution. I gave it a shot and I've been issue-less for over a month.
Old 03-09-2010, 08:05 AM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
I agree with synyster, this was driving me nuts! I'm glad I got it fixed. I figured if I didn't the dimmer switch would wear out from shutting the dome light off and on all the time and that would be something else I would have to fix.
Old 03-09-2010, 08:22 AM   #9
apollo607
Queretaro, Mexico
Explorer '98 XLT 4WD
Vehicle Specs
Quoted: 0 Post(s)
Sweet! I think I will solve an issue that I just find in my X in a similar way, probably going thorugh the wiring on the tail door.
My central tail ligth, which turns on when we push the brakes, with my X all parked and doors closed and locked, it is showing a very soft ligth on, almost invisible. I guess I have some kind of short circuit on this ligth, and I am worry about run off my battery. I think I have had this problem since some time ago, but I did realize until just a couple of days ago since is hard to see this soft ligth that it is showing. Very probably at this moment it is only consuming just a very little energy and thats the reason why at this moment I have not had any issue with my battery yet, but this energy consumption could grow at some point.
Thanks! I will review this on my X and I will let you know if I could fix it.
apollo607 is offline   Reply With Quote
Old 03-09-2010, 03:50 PM   #10
XLTmodifire
Nor*Cal
99' XLT (B4 Autumn Brown)
Vehicle Specs
Quoted: 0 Post(s)
Great thread! I will be checking mine out this weekend after installing my new seat belts.
Thanks!
XLTmodifire is offline   Reply With Quote
Old 03-09-2010, 08:05 PM   #11
High_Order1
near Oak Ridge, TN
2005 Jack Bauer Edition
Vehicle Specs
Quoted: 1 Post(s)
Big ups for the use of the kitchen utensil!!
__________________
____________________________________________
Shawn Hughes
About me / where I've tried to help out here (my back door sticky list)
Please don't PM me. I don't check them enough. Email me , I don't come here anymore, but I'll try to help if I can.
High_Order1 is offline   Reply With Quote
Old 03-14-2010, 01:38 AM   #12
ajitaw
Placerville
'03 XLT FX4
Vehicle Specs
Quoted: 0 Post(s)
Fixed my problem with WD-40 yesterday, I think the majority of the problems are caused by faulty door sensors in the latch, they dry up and get stuck open. A generous spray of WD and your good to go again... unless you are experiencing another electrical problem associated with the doors or like the OP stated. Then I would check inside the drivers door like he did or check the ground behind the passengers side kicker panel, I've heard of that also working itself loose.
ajitaw is offline   Reply With Quote
Old 03-14-2010, 03:29 AM   #13
stuartr
Richlands, VA
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 1 Post(s)
Good write up. Wish it had been there when I had to do mine.
STU
stuartr is offline   Reply With Quote
Old 04-15-2010, 02:50 PM   #14
rlgdguy
Malden, MA
2005 Explorer XLT V6
Vehicle Specs
Quoted: 2 Post(s)
Do you always do this at the "Driver's" door, even if I suspect my problem is with the "Passenger" door? Might sound silly, but why end up taking two doors apart if only one is needed?
rlgdguy is offline   Reply With Quote
Old 04-17-2010, 10:27 PM   #15
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
What problems are you having and why do you think it is with the passenger door?
Old 04-17-2010, 11:54 PM   #16
rlgdguy
Malden, MA
Vehicle Specs
Quoted: 2 Post(s)
Well, I get the "door ajar" light coming on and flashing (well after the doors have all been closed. Maybe 10-20 seconds afterwards), accompanied by the "chimes or dings" sounding off, overhead dome light flickering on and off and the power door locks opening and closing rapidly. Again, all of this is going of or happening at the same time, but only if someone opens and closes the front passenger door. If I'm by myself and open no other doors or any other door (including the rear door and door/glass hatch and accept the front passenger door, nothing happens. It all stops after I drive a mile or so, but occaisionally returns maybe one time and is then ok. Also, if this is happening alot in any instant, when I go to arm the anti theft system, it sounds off immediately. I wait a minute and try again, it usuallu arms. Them almost always during the middle of the night exclusively, it sounds off several hours later.
I just assumed, but could be wrong. That's why I asked if it matters what door to open and check or if I should just check both? Thanks for your inquiry. I look forward to any responses.
Old 04-18-2010, 01:03 PM   #17
derfiticulum
Lincoln, NE
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
If I were you I'd try the WD-40 thing first. A healthy shot in each latch on the car can do wonders.
Old 04-19-2010, 02:01 PM   #18
rlgdguy
Malden, MA
Vehicle Specs
Quoted: 2 Post(s)
I almost don't want to say it and jinx myself, but the wd-40 remedy has seemed to fix the problem. I sprayed the hinges and handles as instructed 4 or 5 days ago maybe and I have not had the problem happen again, accept once very briefly (which I sprayed again for) and have not seen it since. The alarm has also stopped going off in the middle of the night too. I'm hoping this is all it was and I don't end up having to pull the door panel(s) off. I'll post again if I do or experience other issues. Thanks for any and all advice on this ladies and gents!
Old 04-19-2010, 03:00 PM   #19
derfiticulum
Lincoln, NE
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Your problem seems really similar to mine with the exception of the alarm. Mine never went off like that. But I used to have the problem quite often. I sprayed all my latches right around Christmas and haven't seen the issue crop up since.
Old 04-27-2010, 08:53 PM   #20
philipx2000
Canada
philipx2000's Avatar
1995 explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
I am new to the forum but have found some useful information in this thread,
my problem is somewhat different in that the map lights?dome lights interior do no swith on either manually or when I open any of all doors the only light that works is the rear cargo interior light, all bulbs checked and no 12volts coming out at any of the suspect interior light outputs my question is is there a relay or fuse that covers these items so that I can begin to further my fault finding and has anyone had similar problems?
great forum thanks in advance
philipx2000 is offline   Reply With Quote
Reply
Tags
door ajar rear defrost problem
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
