Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
No turn signals or brake lights.
Reply
Thread Tools
Old 03-01-2010, 04:24 PM   #1
happyksh
2002 ST
Vehicle Specs
(Original Poster)
When I tilt the steering wheel down to a comfortable postion the signals nor the brake lights work and I hear a clicking or popping noise. When it's in the highest postion it works just fine.
I've been told it's the multi ###tion switch/sensor(?) and that it's somewhere near the master cylinder. Can anyone confirm this or had this happen to them?
happyksh is offline   Reply With Quote
Old 03-01-2010, 04:27 PM   #2
Fraier
2000 Mercury Mountaineer
Vehicle Specs
If I am correct the multifunction switch is the switch you actually push up or down to turn your turn signal on, wipers and also you hazard lights. One of our F350's needs it replaced
Fraier is offline   Reply With Quote
Old 03-01-2010, 04:35 PM   #3
ncranchero
Sport Trac Moderator
Denver,NC
ncranchero's Avatar
Truckin' on Pat & Charlie
Vehicle Specs
It's the wiring/connector that plugs into your multifunction switch (turn signal/dimmer/wiper switch).
http://www.ford-trucks.com/forums/92...rn-signal.html
http://www.mysporttrac.com/shared/ms...010_4:28:27_PM
__________________
Steve,
2010 Transit CONNECT 145K miles, 2002 Sport Trac 4x4 SOLD
2000 Taurus SES 3.0L 24 Valve DOHC Duratec 87K miles
1994 F150 4x4 4.9L/5-speed 160K miles,
1995 Ranger 2.3L/5-sp/3.73 75K miles "Plain Jane"
How to post photos
ncranchero is offline   Reply With Quote
Old 03-01-2010, 06:31 PM   #4
600remguy
SW Ontario
'04 SportTrac XLT 4Paw
Vehicle Specs
Yup. Its the wires from the switch. Even happens/happened to me in a full size '96 Bronco. Tilting the wheel actually breaks the little tabs that hold the individual wire spades in the larger connector and the single wires pull away from the connection.
600remguy is offline   Reply With Quote
Old 03-01-2010, 09:15 PM   #5
happyksh
2002 ST
Vehicle Specs
(Original Poster)
I just realized I mispelled function, leaving out the letter "n" and got cencored....funny huh? Thanks ncranchero and all.
If I have to purchase the pigtail replacement is it longer than the original as to give more slack? I'm guessing it's not burnt or broken since it still works when tilt is all the way up. I will try pulling the harness and zip tie it in place this weekend when it warms up.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
