logeorge
- March 2, 2010
- Ardmore, AL
- '92 XLT
'92 Explorer has had trans rebuilt.(A4LD) Worked O.K. for a while, then returning from a town 60 miles away, began to smoke from trans fluid on exhaust and fluid dripping out on ground. Thought seal had blown. Towed home. found no leaks. Refilled with fluid, ran thru gears with person underneath watching. No leaks or drips. Drove it for a few weeks, did it again. Rebuilder said to unhook cooling lines to radiator and install aftermarket cooler. Bought one, never got around to installing it. replaced filter, looked O.K.. Blew out cooler lines, cooler inside radiator and factory auxilliary cooler in front of radiator. Not restricted, no debris came out. Took cover off vent, it was clear.(Thought it might be plugged and building pressure) Blew through via rubber hose. Fluid came out dipstick tube. Refilled trans., drove off and on for several weeks. When temp dropped to freezing, trans. wouldn't shift out of second until a 2mile warm-up. Otherwise worked O.K. Sunday it did it again, wife driving. She let it set for about 15 min., drove it home.( 5 miles from where it blew fluid) I'm a pretty fair parts replacer, but know little about automatic trans. diagnosis. Any Ideas?
