Joe Dirt
- October 4, 2007
- 07 Camry
...and get rid of that annoying cigarette lighter plug!
Like many members, I run a GPS. Problem is, I'm OCD about my vehicles, and can't stand extra stuff laying around. As such, I wanted to hardwire my GPS into my truck. So, here is my process, and a short writeup should anyone desire to do the same...
I am wiring into a 1997 Explorer...
You will need one of these harnesses:
I ordered my kit from Amazon, there are several to choose from.
You can NOT cut the cigarette lighter charger plug off and use that wire- the GPS runs at about 3v, and the cigarette lighter plug has a fuse in it. If you cut the wire, you lose the fuse. The box in the kit is the regulator/fuse. If your truck surges for some reason, and you do not have the fusable link in there, you will fry your GPS. Some have cut the cigarette lighter plug and put in a fuseable link, but I wanted to keep mine in case I use the GPS in a different truck. It's easily portable with this setup.
Search for "Garmin Hardwire GPS" on Amazon, or substitute for your GPS manufacturer...
On to the install...
Remove your radio dash bezel (2 screws above the HVAC controls...)
Once the bezel is removed, remove the dash vent deflector by removing the two bolts on the bottom as shown. Lift up and pull out.
Wire your kit in. It's simple- there is a red wire, which goes to a 12v switched wire, and the other black (or white sometimes) is hooked to the ground wire. I wired mine to my aftermarket stereo wiring. I won't show it here, because it's a wiring mess in my Ex, and there are only 2 wires to hook up.
After wiring in, tuck your module behind and below the radio.
Next, pick a location for your GPS. I like it mounted low on the center of the windshield, using the suction cup clip. It's easy to reach, and doesn't obstruct view.
For my install, I ran the mini-USB connector there.
Pop the black defroster vent from the top of the dash.
Push a screwdriver through the separation between the dash and the inner dash to pass your wire through.
Pull the mini-USB through to the other side. **NOTE- after this pic, I placed a small piece of wire loom on the wire to prevent chafing. I don't think it would be an issue, but I had some laying around, so why not...
From the outside, this is where I pulled the wire through.
Place your defroster panel in place, to see where your wire is. I needed to pop one divider out to allow the mini-USB connector fit through.
Pull the wire through the defroster vent, and reinstall the vent.
Place your GPS and plug in. It will now come on with the key, and turn off when you turn the truck off, and charge in between.
This is what you're left looking at- MUCH cleaner!
Happy installing!
Happy installing!
