Why you should not ignore your u-joints | Ford Explorer Forums
Paraphoe
Go big or go home
Willow Grove, PA
'97 XLT
So My truck had a pretty bad squeak that was getting progressively worse. I was told it was a bad u-joint and I finally had the time (and weather) to swing under this Saturday and change them out. I was able to get them changed out in roughly 3 hours, front and rear shafts. Below you will see horrfiying pictures of how NOT to handle u-joint maintence - my rear joint on the rear shaft was such a complete disaster I'm surprised it didn't explode on the highway at some point. I let this go for far too long and I'm lucky it didn't come back to really bite me.
Rear part of the rear shaft, removed:
First sign that something was horribly wrong:
Punched it out, pulled off the first cap, and here's what I found:
...packed with a healthy mix of mud, old grease, and pin bearings that appeared to have been put in an industrial blender.
Took off the OTHER cap, and below is what I found. The cap fully cracked from me slamming it with the BFH, but it was already slightly cracked and in terrible condition.
Replaced the joint:
And replaced the front shaft joint as well:
The moral of the story here is routine maintenence would have prevented the problem from ever getting this bad, but I neglected to check the joint until it started yelling at me (see video: http://www.youtube.com/watch?v=vsn8g58Yjqw), which could have been too late. Learn from my mistake and check those joints.
Jason. I think you broke a needle bearing or two! :eek: Holy! That's probably the worst I've ever seen. Good write-up too.
Wowzers!
Good thing you got it done when you did. A drive shaft spinning at high speeds with one end disconnected can do some terrible damage.
I had a shaft come out at high RPM, it shot out sideways and landed 50' away from the vehicle. No Bueno.
Holy SMUT!
You really are lucky it didn't grenade!
I'm changing mine now... For $20 each not a big deal vs. the potential disaster...
You would be supprised how they hold up with no needle bearings. I broke 2 alloy stub shafts in my front 44 at the same time and when I swapped in a new axle I took the u-joint off at the yoke and found neither side had needle bearings left, just a fine powder. I would have thought the ujoint would have let go but it never did.
Nice catch!
I know, it's actually kinda embarrassing posting with them looking that bad. :rolleyes:
WTF? Like an ICBM!
great pics
grandiosas fotos
