Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Fuel Pump has no power
Reply
Thread Tools
Old 12-11-2010, 04:14 PM   #1
dreamin-on
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have searched and read all of the fuel pump threads and am still at a dead end. Please help.
1992 Explorer Sport 4X4 manual transmission will not start. This vehicle had been parked for a year and previously was a daily driver. The motor turns over just fine but I noticed when you take the key to "on" the fuel pump does not run to prime the engine. I have done the following:
-New battery
-Checked for voltage at the fuel pump connector just above the rear axle. 7 volts. I'm not getting power to the fuel pump.
-New fuel pump relay
-New EEC relay
-Checked for voltage at the inertia switch. 6 volts or so--not 12
-Verified the "check engine" light comes on, indicating to me the PCM is fine.
-Attempted to short the fuel pump relay. Nothing.
-Verified 12V at the fuel pump relay and EEC relay.
-Jumped the inertia switch by disconnecting the plug and inserting a jumper wire.
I should have this beast running by now. Please help.
dreamin-on is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-11-2010, 07:03 PM   #2
James909
Long Island, NY
1994 GMC Yukon 2 Door
Vehicle Specs
Quoted: 0 Post(s)
Welcome to the forum. With the ignition on try grounding the light blue/orange wire in the self-test connector. If the fuel pump turns on then the fuel pump circuit is fine, but the PCM is not triggering the fuel pump relay.
__________________
-James
1992 Ford Explorer XLT 4x4 - Sold
350 TBI
James909 is offline   Reply With Quote
Old 12-12-2010, 10:58 AM   #3
dreamin-on
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks, I'll give that a try tomorrow. Rainy day today.
Old 12-12-2010, 11:07 AM   #4
stanleycr1
Ivor,VA
93 XLT,93 SPORT,92 SPORT
Vehicle Specs
Quoted: 1 Post(s)
I would hang test a new pump assembly if possible to see if it runs when you turn on the key. The fuel gage wires run thru that same plug so there is always power on one pin. NOTE: If you are short on money go ahead an drop the tank before you buy a new pump. There is a good chance that one of the wires have corroded inside the tank an broke off at the terminal. I have seen that twice.
stanleycr1 is offline   Reply With Quote
Old 12-26-2010, 05:00 PM   #5
dreamin-on
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank all of you for the recent help. I have not had much time to work on this rig lately but did get out there the other day. I grounded the light blue/orange wire in the self-test connector and the fuel pump did not run. While I had the wire connected I went ahead and checked for voltage at the fuel pump connector above the rear axle and found 12V.
I am almost certain that it really is the fuel pump now. What do you think?
Old 12-26-2010, 08:48 PM   #6
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
The fuel pump is feed directly from the inertia switch.. If the switch is reading ~6V then the wire you are testing is not the pump wire.
Quote:
The fuel circuit will only register 12v while the engine is cranking.. Once the tach wire goes to Zero RPMs the fuel circuit will drop to 6-7v (which will not run the fuel pump). I would run a hot wire from the battery to either terminal on the inertia switch to confirm the fuel pump runs and/or starts the vehicle. One member ran his X like that for months before tracking the problem down to a loose ground wire in the EEC.
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 12-26-2010, 10:23 PM   #7
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
If you ground the fuel pump test lead, get 12 V at the fuel pump connector, then we can conclude that the circuit seems functional up to that point. We aren't quite at the point yet of definitely saying the pump itself is bad. We could still have a fault in between the connector and the pump, or on the ground side of the pump. At this point, I would probably check the fuel pump ground (On my '92 the fuel pump ground attaches to the body behind the radiator overflow). If the ground looks good, then I'd probably be at the point of dropping the tank.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 12-29-2010, 08:58 AM   #8
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
You should get 12v on both sides of the inertia switch. If you don't, then the problem is either the inertia switch or in front of it (PCM relay, FP relay, .etc).
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 01-15-2011, 03:04 PM   #9
dreamin-on
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Today I hung a new fuel pump from the connector above the rear axle. Turned the ignition to "on" and the pump ran like a champ so I dropped the tank and replaced the old one. She fired right up except the starter did not disengage. That's my project for tomorrow. The fuel pump was essentially stuck from sludge in the tank, it was essentially tar.
Thank all of you for your help.
I'll replace the starter tomorrow and she how she runs.
Picture of old pump:
Old 01-15-2011, 04:04 PM   #10
CountryBoy78
Rice Lake, WI
94 Limited 4.0L 4x4
Vehicle Specs
Quoted: 0 Post(s)
I think you got your money's worth out of that fuel pump........must have been sitting for some time to get that rusty ....wow.....
CountryBoy78 is offline   Reply With Quote
Old 01-15-2011, 04:45 PM   #11
WickedWindsor
Ontario, Canada
351 powered, 1991 XLT 4x4
Vehicle Specs
Quoted: 1 Post(s)
You may want to change the oil before firing it up if it's been sittng a while. Old stale grimey oil can really mess up an otherwise good engine.
__________________
'91 XLT 4DR 4X4
351 EFI Windsor, 4R70W, Baumann electronic controller
Dana 44 SAS Done!, 2" PA Body Lift GONE, SOA, 33"x12.5x15 Pro Comp Mud Terrains. 410 Gears, BW1356 manual transfer case. Homebuilt Custom Exhaust with Flowmaster Super 40 Series.
WickedWindsor is offline   Reply With Quote
Old 01-15-2011, 07:32 PM   #12
dreamin-on
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Oil already changed. Will change again once it's been running a few min.
Old 01-15-2011, 07:41 PM   #13
stanleycr1
Ivor,VA
Vehicle Specs
Quoted: 1 Post(s)
Glad you got it going. Don't forget the Fuel Filter.
Old 01-17-2011, 07:04 PM   #14
dreamin-on
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Starter replaced. Drove it about 10 miles today and it runs great. Now on to the next project, brakes.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
