Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
No off-road use for limiteds?
Reply
Thread Tools
Old 02-02-2011, 08:35 PM   #1
olaverty
Rio Rancho, NM
'11 Limited
Vehicle Specs
(Original Poster)
Ordered my limited a couple weeks ago. Was browsing the owners manual posted on line and read this interesting statement:
"NOTICE TO OWNERS WITH 20 INCH WHEELS AND TIRES
When equipped with 20 inch wheels and tires the vehicle is designed for
on-road use only and not off-road use."
Now obviously it's not gonna change the way I will use mine, but doesn't this effectively preclude all limiteds from off-road use as they come standard with 20 inch wheels? So why would Ford include the 4WD system on limiteds if this is their point of view?
olaverty is offline   Reply With Quote
Old 02-02-2011, 09:17 PM   #2
SuRrEaLNJ
hail to the king, baby!
out of my mind...
SuRrEaLNJ's Avatar
MUNK 07 Focus 97 XL1200C
Vehicle Specs
you shouldnt be ofroading with "dubs" and street tires. for that matter you shouldnt be offroading with a FWD crossover.
the new explorer is designed for on road use and equiped with 4x4 for inclemant weather. i am not bashing the new trucks, all signs point to a supperior ride and features, but the fact of the matter is it is what it is, and its designed what its designed for
__________________
Quote:
Originally Posted by Spas View Post
You are all lunatics, and Jay is your king!
BEN REALLY REALLY LOVES PINK
SuRrEaLNJ loves Hannah Montana
SuRrEaLNJ is offline   Reply With Quote
Old 02-02-2011, 10:25 PM   #3
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quote:
the new explorer is designed for on road use and equiped with 4x4 for inclemant weather. i am not bashing the new car, all signs point to a supperior ride and features, but the fact of the matter is it is what it is, and its designed what its designed for
I fixed that for you.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is online now   Reply With Quote
Old 02-02-2011, 10:47 PM   #4
FordExplorerFan
Tampa Bay, Florida
Vehicle Specs
Quote:
Well, you can switch wheels and tires but adding the 4WD-system later on might be difficult..
FordExplorerFan is offline   Reply With Quote
Old 02-03-2011, 04:49 AM   #5
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Earl, thank you for so elequently stating the obvious.
unclemeat is offline   Reply With Quote
Old 02-03-2011, 06:16 AM   #6
JDraper
Elite Garage Builder
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
It's because of the tire size and profile. Those tires will be very low profile and have a street tread, so no give in the sidewall if you run over rocks. Most likely written in by a lawyer not wanting the owner to sue Ford to replace his rims when they get dented up.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is online now   Reply With Quote
Old 02-03-2011, 07:48 AM   #7
bender
Johnstown PA
'08 Limited
Vehicle Specs
Yes my 08 limited with 20" wheels said similar, also in the 08-10's if you get the 20s, they only come on 2wd and AWD (no low-range 2 speed transfer case) statement it strictly because of the wheels and low-pro tires.
bender is offline   Reply With Quote
Old 02-03-2011, 09:44 AM   #8
FLOffroad
08 Sport Trac Limited V6
Vehicle Specs
Those tires would probably just pop if you tried to take them offroad. Best ratio for tire size:wheel size is around 2:1 for offroading, 20" wheels with 30"ish tires is just not smart for offroading.
FLOffroad is offline   Reply With Quote
Old 02-03-2011, 11:00 AM   #9
1AJeremyD
EF Vendor
Mass
95 XLT 4.0
Vehicle Specs
I wouldn't really want to go and bang up my, probably 500 a piece, rims off-roading in the woods. I would like to see what is possible with the new explorer for off road capabilities. Just gotta wait and see what comes out.
__________________
Jeremy
1A Auto
888-844-3393
Shop for Ford Explorer Parts
1AJeremyD is offline   Reply With Quote
Old 02-03-2011, 04:18 PM   #10
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
I plan to get a set of the base 17" steelies to mount my Winter tires on for my Limited. I guess that means that I'll be okay to go rock crawling then.
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is online now   Reply With Quote
Old 02-03-2011, 04:52 PM   #11
Mishtar
Victoria, BC
2011
Vehicle Specs
Quote:
Originally Posted by peterk9 View Post
I plan to get a set of the base 17" steelies to mount my Winter tires on for my Limited. I guess that means that I'll be okay to rock crawling then.
I plan on getting the 17's as well Peter.
Mishtar is offline   Reply With Quote
Old 02-03-2011, 04:54 PM   #12
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
20" wheels for off-roading is just fine, you just need 40" tires to match them.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 02-03-2011, 05:39 PM   #13
Gandalf
Southern California
2011 Limited
Vehicle Specs
Sorry, but this issue has me confused. What, exactly, is meant by "off road"? There are all kinds of roads, from paved, through dirt and gravel, to roads where even a stock Explorer of any generation would be questionable. As long as its a "road", then I am OK? (note, that last question was facetious) So then, where is it, exactly, that I am not supposed to take a 20" wheel equipped Explorer? Well, other than the obvious boulder field or log strewn forest...
I understand that a lot of this is legal CYA by Ford, so they won't get sued because someone's Explorer won't go through the same terrain a fully outfitted Wrangler will, but still it seems rather fuzzy to me.
Gandalf is offline   Reply With Quote
Old 02-04-2011, 05:46 AM   #14
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
This is an Explorer enthusiast website. You are obviously confused. The 91 Explorer (gen I) was 4x4 of the year when it came out. Before I lifted mine I took it everywhere offroad, mud rocks, and sand. It did just fine. Also see the home page of this site for a description. My 04 Ranger Level II stock (gen II is way better than a similarly outfitted jeep. That vehicle goes everywhere. The long wheel base makes it ride and drive much better than any wrangler. I spend a lot of time offroad, hobby and occupational.
A 20-inch wheel equipped explorer will do just fine on wet and snowy pavement or maintenaned gravel roads. Even better would be the mall parking lot.
Old 02-04-2011, 06:29 AM   #15
Gandalf
Southern California
2011 Limited
Vehicle Specs
Um, my question is about the practical limits of what the new Explorer can do off pavement. It has nothing to do with how well earlier generations handled in the back country and it certainly has nothing to do with any kind of Explorer vs Jeep comparison.
Old 02-04-2011, 09:37 AM   #16
uniquename
Twin Cities, MN
'11 XLT
Vehicle Specs
I've spent enough time offroad, I will try to give you a realistic expectation.
With the 20s, I would avoid places where a rock (wouldn't need to be big) could scuff the rims up. The biggest concern is the tires. Those things will not help you in mud, sand, etc. I am NOT bashing the explorer, more the tires. If what I have seen/read is right, expect to go a little deeper into the woods than an AWD car simply based on ground clearance. I've seen lots of stock XJs and ZJs (jeep suvs) look quite capable with decent tires, and look pathetic with the wrong tires.
uniquename is offline   Reply With Quote
Old 02-04-2011, 11:12 AM   #17
Gandalf
Southern California
2011 Limited
Vehicle Specs
Thank you! That is the kind of info I was looking for!
I am seriously considering a new Limited. While I don't go off road as a rule, I do occasionally take a non-paved road to a cabin or a camp site in the mountains or the desert. I'd like to know how much the 20" wheels will limit me, especially as compared to my stock 93 XLT.
Old 02-04-2011, 01:02 PM   #18
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
My bad. I just thought I needed to defend my junk. Some here have been making false statements about older Explorers.
Old 02-04-2011, 01:08 PM   #19
uniquename
Twin Cities, MN
'11 XLT
Vehicle Specs
And plenty have been making them about the new ones too
At the end of the day, hopefully we all are happy with the choice we made.
Old 02-04-2011, 02:02 PM   #20
Gandalf
Southern California
2011 Limited
Vehicle Specs
Peace.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
