The cause is....drumroll......rain.
The roof is metal and the rain strikes it with such velocity that the kinetic energy of gravity interacting directly and vertically upon the water molecules at a standard rate of 9.8 meters/second, (not accounting for the surface area/drag ratio) is instantaneously stopped. Or transferred rather (since energy can neither be created nor destroyed) into an audible energy known commonly as "noise" since it carries no particular pattern or melodic tune.
The corrective action to take is to
A.) suck it up.
or B.) move to the desert.
Or you could pull down the headliner and try something like a spray on rubberized liner or Dynamat which is made more for the car audio field but can help to block outside noises.
Geeze. Kids with their MTV and Rockin and Rolin' don't know about basic science these days.
Just messin' with ya' man. Welcome to the forum.
well, I was thinking the roof was probably a hollow area big enough to warrant some insulation due to the thickness of the roll cage & it was left out or not thought of......thanks BrooklynBay, thought that's where it was.........my bad!!
Your right. There's some space in there. Dyna-mat and the likes are all pretty thin and can fit in nearly anywhere. That's your best bet if the noise is getting to you. If your not into pulling apart you new vehicle you could probably get a car audio shop to install some for a price.
Terry - Waiting on mine too and have also seen this complaint elsewhere.
I'm wondering if it has to do with the cabin being so quiet that when it does rain, the sound seems amplified more than we're used to in cars with more road noise present all the time...
Haven't heard it with mine yet, but I haven't been in a driving rainstorm either. Had it out in light to moderate rain yesterday and didn't notice anything different.
Thought I'd update my experience on this. Today on my way to work I drove through a torrential downpour (wipers on high had trouble keeping up) and noticed no excess noise from the rain. It was about the same as it is in our Focus and was with our F-150. Unless Ford put a fix in before we got ours, it's a non-issue.
When I go through (5 times already since picking it up on Wednesday!) the car wash, the 2011 Limited is much more quiet compared to the 2007 EB Explorer.
I've noticed a rather loud rain noise in our X too. I tend to attribute it to driving under trees and having larger drops than usual hit the roof. Sounds like acorns hitting the roof!
