#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > Stock 2011 - 2016 Ford Explorer Discussion
Notices
Stock 2011 - 2016 Ford Explorer Discussion 2011 - 2016 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Cabin fuse box location
Reply
Thread Tools
Old 06-23-2011, 09:36 AM   #1
krayzie32
VA
11 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've searched these forums and google and I still can not find my fuse box. I keep seeing "below and left of steering wheel near the brake pedal"... I do not see anything except for 2 screws that that are holding a large black panel together, which goes up to the steering wheel. I would like to pull the sync fuse in hopes of sync behaving correctly.
Thanks
krayzie32 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-23-2011, 10:03 AM   #2
jrmexplorer
2011 Limited
Vehicle Specs
Quoted: 29 Post(s)
Quote:
Thanks
It's above the parking brake, not the normal brake and its mounted so that it would be parallel to the drivers legs when the driver is seated in the driver's seat. There is a black cover that needs to be removed.
jrmexplorer is offline   Reply With Quote
Old 07-03-2011, 01:56 PM   #3
plex
Toronto, Ontario
2011 LTD
Vehicle Specs
Quoted: 0 Post(s)
2011 Explorer Fuse Box Locatioin
I've looked very carefully everywhere above both brake pedals, and cannot for the life of me find the fuse box. Any additional help would be appreciated.
Thanks!
plex is offline   Reply With Quote
Old 07-03-2011, 05:04 PM   #4
NEWPORTNJ
JERSEY CITY
2014 TUXEDO BLK LTD 302A
Vehicle Specs
Quoted: 93 Post(s)
Look at the manual book mybe the canaidian model has it in a differnt place ?? But in mine's it's in right by the brake pedal right above check hard with a flash light !!
NEWPORTNJ is online now   Reply With Quote
Old 07-03-2011, 06:00 PM   #5
kdog
Kailua, HI
2011 LTD
Vehicle Specs
Quoted: 0 Post(s)
It's not really easy to see, and definitely not as large as old fuse panels were, but it is right above the brake pedal. Grab a flashlight and lay down on the floor mat.
kdog is offline   Reply With Quote
Old 08-01-2011, 09:31 PM   #6
krayzie32
VA
11 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So do I have to get on my back and look up to see it? I still can not find the box... can someone post a picture of the box location? My touchscreen is now black and will not turn on and I am 100+ miles away from any dealership... thanks for any help.
Old 08-01-2011, 10:01 PM   #7
kdog
Kailua, HI
2011 LTD
Vehicle Specs
Quoted: 0 Post(s)
Sort of. It's a b**** to get to.
FWIW, I posted this in another thread but I finally had Ford open up my dash to get a PN off the module. They discovered it wasn't plugged in all the way, causing me all the headaches with MFT/Sync. Once they plugged it in - smoooooth sailing.
Old 08-01-2011, 10:14 PM   #8
lookgoodn43
Mirabel,Qc, Canada
2011 XLT AWD Explorer
Vehicle Specs
Quoted: 0 Post(s)
Canadian model is in the same location.......
lookgoodn43 is offline   Reply With Quote
Old 08-02-2011, 06:35 AM   #9
StunnedMonkey
Fort Wayne, IN
2011 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Thanks!
I've never found it on my EX either. I think it requires the agility of a trapeze artist to get to. Like you, I can't even find it, let alone get into it. I've given up. If you're trying to reset MFT I think disconnecting the battery for a few minutes accomplishes pretty much the same thing. That's what I do anyway.
StunnedMonkey is offline   Reply With Quote
Old 08-02-2011, 08:16 AM   #10
krayzie32
VA
11 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I heard disconnecting the battery is not a good idea.... However, since I'm on vacation and not close to a mechanic, I might have to resort to that.
Any other advice/pictures on where to find the fuse box?
Thanks
Old 08-02-2011, 09:35 AM   #11
calabrese94
Brooklyn NY
11 limited white 302A
Vehicle Specs
Quoted: 0 Post(s)
It on the left hand side on top and it not that far deep from the panel
calabrese94 is offline   Reply With Quote
Old 08-02-2011, 11:30 AM   #12
harlenm
Shelton, CT
2013 Limited(lemon swap)
Vehicle Specs
Quoted: 2 Post(s)
If you look up under the peddles to the left, along the side of the car, you'll find it. Here is a pic, a little blurry, but you'll get the idea.
harlenm is offline   Reply With Quote
Old 08-02-2011, 12:57 PM   #13
w1kedz
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
lol.. this thread just highlights the stupidity of the engineers that designed the location for the panel that houses "user replaceable fuses"... I mean come on. I've never had a car that I had to bend my body 3 different ways to find the panel, and another 2 ways to actually be able to replace a fuse on.
Why isn't this panel under the plastic piece on the left side of the dash? There is plenty of room in there and you can actually access it without being a circus actor.
I feel sorry for anybody that is over 6'2", or over 250lbs... cause there's almost no way they are going to be able to get into a position to identify the correct fuse and pull it. And if they do, getting it back in is going to take a miracle.
I know!!! The fuse box placement must have been part of the engineering group that developed MFT!!
Old 08-03-2011, 10:39 AM   #14
krayzie32
VA
11 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
harlenm,
The picture helped me tremendously. I was looking in the wrong place and at the incorrect angle. The box is on the far left (looking as if you are driving) behind a bundle of wires and parallel to your body up against the left side of the vehicle. You don't have to get on your back, just your right side looking toward your left.
I found fuse 29, fired up the SUV and now everything is working again.
Thank you again harlenm. You saved me hours of silence in my 7 hour drive back home and now the wife won't be pissed off anymore about the SUV
[QUOTE=harlenm;2780990]If you look up under the peddles to the left, along the side of the car, you'll find it. Here is a pic, a little blurry, but you'll get the idea.
Old 08-03-2011, 10:49 AM   #15
harlenm
Shelton, CT
Vehicle Specs
Quoted: 2 Post(s)
harlenm,
Quote:
Glad I could help.
Old 09-26-2011, 12:49 PM   #16
dbcutbirth
Monahans Texzas
2011 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Where is cabin fuse box?
Where is passenger fuse box? The manual said under and to the left of the steering column and by the brake-I cant find it. 2011 Ford Explorer
dbcutbirth is offline   Reply With Quote
Old 09-26-2011, 02:08 PM   #17
Woolaroc
2012 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
You and me both. I hear its a pain to find, but I spent 5 minutes looking all around the break and up under the steering column and couldn't find it. Might have to start removing trim pieces.
Woolaroc is offline   Reply With Quote
Old 09-26-2011, 02:22 PM   #18
calb
2012 AWD Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
This thread has a picture and description of location of fuse box:
http://www.explorerforum.com/forums/...e+box+location
calb is offline   Reply With Quote
Old 09-26-2011, 06:23 PM   #19
Woolaroc
Vehicle Specs
Quoted: 0 Post(s)
Ok Found it on my 2012. There is NO way I can get to it. I'd have to remove the break peddle just to get my head in a position to see what I'm doing. It looks to be a mile behind a trim piece, do you have to remove this?
Old 09-26-2011, 06:56 PM   #20
Eaglelake2007
2011 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
Fuse box
No trim pieces have to be removed for the 2011. Great prior thread. Put seat all the way back. Get a flash light and put your head in front of the break pedal. Shine your light up and towards the exterior of the car right above a couple electrical plugs. Very small panel. Pull the cover and grab the white pinchers off the inside of the lid. I found the hardest part is reinstalling the tiny fuse after you pull it. Good luck.
Eaglelake2007 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2006 under dash fuse box Victoria dos Stock 2006 -2010 Explorers 1 10-31-2014 05:09 PM
Kick Panel Fuse Box Accessory Fuse #? wisedetailz Stock 2002 - 2005 Explorers 1 07-30-2014 02:13 PM
2004 fuse box question p-funk Stock 2002 - 2005 Explorers 10 03-27-2014 10:15 PM
explorer fuse box where is it? mazzasec Stock 2002 - 2005 Explorers 3 01-03-2008 12:09 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
