#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Bypassing Low pressure switch on 04 Explorer XLT
Reply
Thread Tools
Old 08-30-2011, 03:51 AM   #1
Saik
2004 Ford Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
How do I bypass the low pressure switch so the clutch can engage so I can fill it with R134a+?
Thank you!
EDIT:
You guys are not getting it.
I KNOW HOW to recharge the system with R134. The problem is I CANNOT RECHARGE it because of the low pressure switch that prevents the clutch from engaging. Making it impossible for me to recharge the system.
Saik is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-30-2011, 09:47 AM   #2
matt0248
Chicago
02 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
unplug the electrical connector and jump it with a paper clip.
matt0248 is offline   Reply With Quote
Old 08-30-2011, 05:12 PM   #3
Saik
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Dk Exp
Okay, which relay do I unplug, and what socket do I put the paperclip endings in?
Old 08-31-2011, 07:27 AM   #4
matt0248
Chicago
02 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
you need to find the low pressure cut-out switch. It is inthe low side refridgerant lines of the ac system. not 100% sure where it is on these as I have never needed to know....yet.
Old 08-31-2011, 10:59 PM   #5
Saik
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I wish there was a diagram on how to do this.
Old 09-01-2011, 12:09 PM   #6
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
Quoted: 16 Post(s)
Low press should be a smaller dia line. Another way I give initial charge is disconnect and power the A/C clutch itself so it pumps in the refrigerant.
rocco123 is offline   Reply With Quote
Old 09-01-2011, 06:55 PM   #7
Saik
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
Can I have step by step directions on how to do this?
Edit: I know how to charge the system via low pressure port. The problem is the clutch wont engage because of the low pressure switch. Which makes it impossible to recharge the system.
Old 09-02-2011, 09:50 AM   #8
JCR
Lancaster, Pennsylvania
2002 XLS
Vehicle Specs
Quoted: 5 Post(s)
If you are recharging from the small cans you can buy at your local auto parts store, just hold the first can upside down and it will flow into the system. Then finish the charge slower by holding the next can upright.
JCR is offline   Reply With Quote
Old 09-02-2011, 06:07 PM   #9
Saik
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Old 09-02-2011, 06:11 PM   #10
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 205 Post(s)
I've never looked on that new of an X, but normally I find them near the accumulator on 1st gens, and on my friends f-150.
I don't know if it will help, but if you flip the can upside down you do get more pressure on the low side. I never "leave it" upside down, but I normally put the first can in alternating from up side down to right side up to keep the pressure about 40 psi.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 09-02-2011, 07:21 PM   #11
JCR
2002 XLS
Vehicle Specs
Quoted: 5 Post(s)
Like Maniak and I have said just turn the A/C on max hook up your hose to the low pressure side with a can of R134a held upside down and soon the compressor will kick on, then fill it slower the rest of the way and you're done.
Old 09-03-2011, 12:21 AM   #12
Saik
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
When I turn the A/C on it will not engage the clutch because there is NO CHARGE in the system. Therefore I CANNOT CHARGE because the CLUTCH IS DISENGAGED. People usually bypasses this low pressure warning by jumping the switch to trick the clutch into engaging even with NO CHARGE.
Now I need to know HOW TO JUMP THIS LOW POWER SWITCH so I CAN CHARGE the system. Thank you
Old 09-03-2011, 05:33 AM   #13
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 205 Post(s)
Well, I cant answer the "where question" but I can say we are missing something here..
You do Not need the a/c to engage to start to charge it. You can get 12 ounces or more into a system when it is off. If you put the can in a cup of hot water you can get even more in.
Once you have a can in there the compressor should turn on although it may cycle during the charge process.
~Mark
__________________
Old 09-07-2011, 05:43 AM   #14
Saik
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
When the clutch isnt engaged the pressure is in the red zone and the R134a refuses to go into the system. However when the clutch is engaged the pressure is normal, and allows the system to be charged.
Help!
Old 09-07-2011, 07:34 AM   #15
matt0248
Chicago
02 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Help!
not sure what "the red zone" means. But if the clutch is not engaged there will be no suction on the low side to pull the freon from the can into the system. When the clutch shuts off the pressure in the high side and low side start to equalize, meaning that the pressure on the low side goes up. this is normal.
Old 09-07-2011, 04:15 PM   #16
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 205 Post(s)
Help!
I looked through rockauto and could not find a picture of where the low pressure switch connects to. I did find a picture of the actual switch and it threads on like I expected it to.
My best guess will be near the accumulator/receiver/dryer..
Also, When you start to charge a system you evacuate it first. This pulls the moisture out of the system and puts a vacuum in the system. This way you can get the first can or so into the system which should be enough to get the compressor to run. It will most likely cycle, but while its cycling it will pull in the r-134 when the compressor is engaged.
Another possible option if you still can't find the low pressure switch to bypass is to power the a/c clutch yourself. Normally its just 12v on 1 side and ground on the other and viola, the clutch is engaged.
One last thing. It sounds like your just using one of those cans with a gauge on it from the auto parts store. Personally I don't like those as they don't normally have pressures listed and you can't know what the high side pressure are either. If your high side pressure gets too high that can also turn of the system on newer vehicles (ones with a high pressure switch too).
~Mark
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
04 XLT stalls at low speed cruise control... replace TPS? Burnout Under the Hood 1 08-08-2011 11:54 AM
1995 Explorer XLT. Low fuel pressure. tgavel Stock 1995 - 2001 Explorers 10 07-03-2011 01:16 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 11:03 AM
98 xlt sohc v6 oil pressure switch problem???? astrochimp Under the Hood 0 05-14-2007 11:25 AM
New '04 Explorer XLT Spennyd New Member Introductions 0 01-11-2005 04:35 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
