derek_redneck91
- December 9, 2011
- Springfield, Ontario
- 99 Explorer Sport 4x4
Hello all, new to the site and I wanted to share a success story about the brown wire mod on my 99 Explorer. I read for hours on this mod (literally every thread about it on this site). I know the risks, and even though I'm 20, I'm still not into roasting off $1100 tires or messing up my t-case, seeing as it's my vehicle and I pay for everything! I know there are several threads about this mod, but I'm not asking any quesitons here, I'm merely giving some information for those thinking about doing it.
I had to install a new seat so I figured I'd give it a shot. Once the seat was out I just cut the carpet, and found the connection that goes to the transfer case. There is already a cut in the carpet for the electronic seat control, i just made it longer (cut towards the dashboard) and branched out in a y shape to give me more room. I simply cut the brown wire after the connection that goes towards the transfer case, and soldered in some new wire that runs under the carpet and under the frame of the console to hide all wires, to a lighted switch just above my cup holders (obviously a little modification to the plastic has to be made...no big deal! I grounded it to a bolt holding the metal frame of the console to the body. I used one of the switches that people use for nos (they have a plastic cap that you flip to turn the switch on). All I did was shave off the metal piece on the cap so that I can reverse it. This means that when it is closed, it is on and you can't accidentally switch it off, and when I open it and flick the switch it is off. I can still engage 4x4 high with the switch off, and when I turn the switch off there are no warning lights that come on saying something is wrong. It works just as stated in the other threads. And at night it is interesting to see how much the power for the auto 4x4 is cycled.
I will reiterate though as said in other threads, that doing burnouts, and allowing for excessive wheel spin, is BAD for these transfer cases. Also, you have a "live" front axle anyways, so keeping the switch off has NO benefits! It's just fun to drift around a corner on a dirt road every once in a while
Thanks for reading and I hope this clears up some questions anyone might have had.
Sorry folks, pictures on the camera have corrupted...from the description you can easily tell whats going on under the seat. Will try and get a picture of the switch location and setup.
