| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Colorado
'94 Limited
Replaced sending unit, still no fuel gauge reading
The fuel gauge on my 94 Limited hasn't worked (properly*) for probably 7 or 8 years. Every time I get to 300 miles on a tank I'd refill.
Well I finally got around to the task of cutting a hole in the floor, pulling out the old sending unit, removing the original pump and placing it on a new sending unit with a new strainer, and placing that back in the tank. And replaced the fuel filter. Turn it on and still no reading at the gauge... fffffuuuuuuuuuuuu-!!! What do I check next? *I mentioned it hasn't worked properly for 7 or 8 years. What I mean by that is the gauge would often show an initial full reading when I turned the Explorer on. But over the course of a couple miles the gauge would slowly but surely drop to empty and remain there for the duration. This morning when I turned it on after replacing the sending unit it just stayed dead on the empty side. I threw my hands in the air and came in to take a multi-hour/beer long break. Please advise and thanks in advance! |
#2 |
Colorado
'94 Limited
So I started looking over the old sending unit that I removed and sure enough the brass float has a hole in it. A fair sized one right where it connects to the wire hanger.
This made me question the sending unit I just put in. So I popped the lock ring back off and shined a flash light in there. I've currently got a full tank of gas and the float is clear up at the top of it, floating. Turned the key and still reads empty. Although the gauge did move around a little again. When I turned it on it was already above empty and it dropped down and then slightly lifted again. In conclusion, I don't think my sending unit is bad and I don't think my gauge is necessarily bad. The truck runs great and doesn't cut out or experience a loss in fuel at all. Anyone have any ideas? |
#3 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Check the resitance at the fuel pump connector. If it reads good there, try checking the fuel gauge itself.
It may be just a bad connection in the plug-or a broken wire in the circuit. This thread may help http://www.explorerforum.com/forums/...der+resistance |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Changing fuel filter on third generation X | SyberTiger | Stock 2002 - 2005 Explorers | 25 | 10-04-2012 08:51 AM |
| Computers, Sensors, MILs, CELs, PCM Inputs and More | ExplorerDMB | Explorer, Ranger - Computers, Chips, Tuning | 58 | 03-20-2011 04:12 PM |
| Step-by-step: replacing factory gauges & sending units with Auto Meter for 4.0 Ford | Dannyboy | Technician's Tips and Tech | 24 | 08-12-2008 10:42 PM |
| Fuel sending unit is a guarter tank off | Josh | Under the Hood | 2 | 03-29-2005 07:24 AM |
| Thread Tools | |
