#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Weird alarm/shutdown/battery drain problems
Reply
Thread Tools
Old 04-03-2012, 12:44 PM   #1
Adasha
Friendswood, TEXAS
2003 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I just bought a used 2003 Explorer and have had this happen 3 times now.
The first time I was parked and loading the vehicle with the key in the ON position, engine off, my window down, back gate open, with my headlamps on. This was about ten minutes. When I went to leave, my headlamps blinked quickly as I turned the key, the red light on the dash for the alarm blinked quickly, and when I tried to start it, it clicked and would not start.
I waited a bit and tried again. No start. I read my Ford book while waiting for road service. I read about the PATS system, and since then have also seen some people thinking the alarm system is running down their battery while sitting and searching for the key to start it. I'm not sure, but when the man got there he hooked up the battery to charge and it did the same thing at first. I got out of the car, hit the lock button twice and it beeped twice instead of once. I hit the unlock button once, got in, tried to start, click click click. I took the key out and turned it upside down and it started.
Ran fine after that for days.
Now it has done it again. Did same thing with jumping with battery, etc. it does nothing, like the battery is totally dead, but it is not that old.
Any help on what this is and how to fix it?
Adasha is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-03-2012, 03:40 PM   #2
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 67 Post(s)
Whether or not the battery you have isn't that old, get it checked out (tested) anyhow at a parts store. They/parts stores, test batteries for free. A lot of these starting/electrical problems in these EX's can be attributed to a bad battery. Also check all your battery connections, make sure they are clean/free of corrosion and tight. Check the water level in the battery as well. Use "distilled water" to top off the battery if needed. If everything with the battery checks out okay, then move on to the charging system/alternator. Get the alternator tested at a parts store.
Exproblems is offline   Reply With Quote
Old 04-03-2012, 06:29 PM   #3
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Welcome aboard!!
When you press the key fob twice and the horn beeps twice that is an indicator that there is an issue. For instance if I have a door open and hit the key fob twice, the horn will beep twice, indicating the issue.
I had similar electrical issues with my 02 xlt. When I hit the key fob twice, the horn would sound twice. The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, the delayed accessories didn't work, etc. Most recently all 4 windows stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 2 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums/...d.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums/...d.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Could also be related to the door ajar switch.
Here is a great thread for checking/replacing the door ajar switch, thanks to borland for the awesome write-up: http://www.explorerforum.com/forums/...d.php?t=249253
Quote:
Originally Posted by thepotroast View Post
That is a great write up.
On a side note, before going through a complete replacement of the switch, you can spray WD40 into the door latch opening on each door, as these become stuck sometimes....and this can alleviate the issue.
This worked for me, after going for more than a year of the "door ajar" light coming on occasionally...mainly after a car wash, high humidity, or rain....making me unable to lock/arm the vehicle from the door keypad and keeping the dome lights on. Worth a try....it worked for me
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
Good luck with the fix.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 04-04-2012, 10:28 PM   #4
Adasha
Friendswood, TEXAS
2003 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quick update. Had the battery tested and it is fine. Going to have alternator checked tomorrow.
Old 04-05-2012, 08:28 PM   #5
Adasha
Friendswood, TEXAS
2003 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Ok, alternator tested ok. We cleaned the battery terminals and it has started several times. I'll see how it does, but I still think there is some weird perimeter alarm battery drainage going on...
Old 04-06-2012, 07:41 AM   #6
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quoted: 67 Post(s)
[QUOTE=Adasha;2942762] We cleaned the battery terminals and it has started several times. >>>>>>>>>>>>>>>
So the battery terminals were "corroded" then? If it now starts better than it did before after cleaning up the battery terminals, then you probably found the source of your problem.
>>>>>>>>>> I'll see how it does, but I still think there is some weird perimeter alarm battery drainage going on...>>>>>>>>>>>>>>>
Not sure what you mean by "weird perimeter alarm" battery drain, but the alarm system along with other on board computer related systems will drain the battery down as they sit un-used over time. They are always actively draining power from the battery while the vehicle is turned off.
Old 04-06-2012, 08:57 AM   #7
D Hook
Omaha, NE
06 Explorer Limited V-8
Vehicle Specs
Quoted: 65 Post(s)
Is this an aftermarket alarm system?
I've had instances when a car will just click, not crank and then wait a few seconds and try again and it starts just fine. Corrosion in the terminals will do that. Cleaning the terminals is a good first step.
Please keep us updated on what you find.
__________________
2010 Expedition Limited LE --wife's DD & boat hauler
2006 Explorer Limited V8--Replaces the '02
1998 Mark VIII LSC--AKA Barca lounger on wheels. For Sale!
*Registered Smart Ass in all 57 states
D Hook is offline   Reply With Quote
Old 04-06-2012, 03:39 PM   #8
jad2411
El Paso, TX
blue 02 xlt & white 02xls
Vehicle Specs
Quoted: 1 Post(s)
Well since there is no stock alarm then yes I assume it s an aftermarket one, unless he means the stock keyless entry.
The other thing to check is the battery cables, on my truck we had those issues that everyone told me were caused by the alarm, it was the neg cable to the battery, it was all corroded under the sleeve, I replaced it and it has worked great ever since
__________________
If interior is to exterior and
include is to exclude, then
increment is to:
jad2411 is offline   Reply With Quote
Old 04-25-2012, 06:21 PM   #9
Adasha
Friendswood, TEXAS
2003 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Not fixed!!!!!
IT IS NOT FIXED...
Battery and alternator test fine.
Try to start it - click click click with all gauges going back and forth fast and crazy and won't crank.
ARGHHHH
Old 04-25-2012, 06:43 PM   #10
D Hook
Omaha, NE
Vehicle Specs
Quoted: 65 Post(s)
I only had that happen once on my Explorer. It was a bad battery. Nothing but clicking and gauges went crazy.
I know you say they tested fine but if you can put in a new one or one from a known good source, you might find out more info. Borrow one from a friend or another vehicle you own?
Does this have an aftermarket alarm or remote start system?
Also check the cables for corrosion. Sometimes it's difficult to see if it's inside the wiring cover.
Good luck and keep us updated.
__________________
Old 05-06-2012, 10:40 AM   #11
Adasha
Friendswood, TEXAS
2003 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
The alarm evidently came with it because it is fully explains it in the owner's manual that came with it. It is the strangest system and I would love to dismantle it if possible. I am all for locking criminals out, but it locks me out, too!
I am going to get a new battery. Let's see how it goes. Any way to make these things not use the battery even when car is off?
Old 05-06-2012, 12:52 PM   #12
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
try replacing the cables to the battery, the whole thing.
Mine was doing the same thing the neg cable was nasty green under the plastic sleeve, under 30 bux and so far no more issues
__________________
increment is to:
Old 05-06-2012, 03:48 PM   #13
Mario81587
Newport, NC
02 Mountaineer AWD
Vehicle Specs
Quoted: 0 Post(s)
I had this exact same problem on my Nissan Sentra. The battery tested good but the issue kept repeating itself. Go and get the battery tested again, but this time leave the ignition on and let it die down some to the point where it won't start. Then have them test the battery. I did this on my Sentra and the battery tested bad. I'm guessing that when I drove to Wal-Mart, where I had the original battery installed, they tested it right after I shut the car off, so it still had a full charge and tested good. The second time, after letting it sit with the ignition on, and then testing it, the battery charge was low, therefore it tested bad.
- Mario
__________________
2002 Mercury Mountaineer AWD V6
2004 Nissan Sentra SE-R Spec V - all options
2007 Toyota Camry Hybrid - all options
Mario81587 is offline   Reply With Quote
Old 05-09-2012, 12:32 AM   #14
lyricsembraceme
elk grove
2004 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
can someone post pictures of wiring I found a wire and have all the same issues.. it has a number 3 on the tip and its pink plastic under drivers side dash, no radio, no power to windows, mirrors, gages and click, click, click... the wire looks like it would hold a glass fuse. battery doesnt take water. help!!!
lyricsembraceme is offline   Reply With Quote
Old 08-02-2012, 05:28 PM   #15
explorer5
Vehicle Specs
Quoted: 0 Post(s)
I just had the same issue last night...tried jump starting it and the same issues with the crazy gauges and red blinking theft light.
Do you think this would be the same solution as below?
http://www.explorerforum.com/forums/...ht=%22theft%22
explorer5 is offline   Reply With Quote
Reply
Tags
2003, battery, drain, explorer, pats
Similar Threads
Thread Thread Starter Forum Replies Last Post
Odd problems fixed - speedometer, odometer, ABS, weird headlights, no start, more! NewOrgnlDave Under the Hood 4 07-14-2011 07:49 AM
MFT Problems - Is Factory Nav a Common Cause? dco43054 Stock 2011 - 2016 Ford Explorer Discussion 5 06-20-2011 06:16 AM
weird sputtering/fuel/ECM problems...please help NICE59FORDF100 Stock 1991 - 1994 Explorers 7 11-01-2005 12:04 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
