| Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Florence, SC
2003 Explorer
Spartan Locker
Well, after reading a lot of threads about different lockers I decided to go with a US Standard Gear Spartan Locker. Like any lunchbox style locker, it goes in the place of the spider gears. The install of the locker was very easy. I used the thread http://www.explorerforum.com/forums/...d.php?t=318076 to help during install.
The locker came in a nice box. ![]() ![]() ![]() It came with a set of instructions on how to install the locker inside the open carrier. The Spartan Locker DID NOT have to be modified in any way to fit the ford 8.8 IRS. The axle spacers had the correct inside diameter. ![]() ![]() Not the best way to measure the inside diameter but hey, it worked. Getting the diff out wasn't all that hard. I had a buddy with me helping getting it out. I cleaned the inside of the diff with break cleaner (not perfect) but I got the major stuff off. ![]() Btw, the tolerance for the Spartan Locker is between .145-.170 inches. That was measured with feeler gauges. Do not use thrust washers for this locker. It specifically states not to use them. So make sure you get them out when you remove the spider gears. After install: ![]() After you get everything back together, go have some fun!!! ![]() ![]() ![]() It works excellent. NO problems. I don't hardly hear it on the road. You can hear it when making sharp turns in a parking lot. I used Lucas 85w-140 gear oil. And if you have a noisy rear end, this gear oil will help lessen that noise. It is about 10$ a bottle and you need to get two. (Ford manual says to put 1.7 quarts in rear axle) Any questions, feel free to ask. __________________ 2003 Explorer 4.0 Volant CAI Volt HID headlights/DDM Tuning HID fogs BTF (2/1.5) spacers Underdrive pulley Spartan Locker |
#2 |
Ashland Va
2005 Xlt 4x4
Great write up. Can't wait to regear and lock mine this summer
__________________ Factory DVD, third row, rear A/C, Moon roof, Advancetrac RSC, Tow package, Leather everything, Eddie Bauer running boards.MODS- deep transmission pan w/dipstick, 1.5" Body lift, Expedition front tow hooks, Treadwright Guard Dog M/T 265-75/16 C Ply, Telescoping steering wheel mod, 4.56 gears limited slip front and rear,brembo brakes,front skid plate, Cb.FUTURE MODS-rock sliders, oba, steel front bumper w/ warn VR12000, possibly a M90 |
#3 |
Virginia
2008 XLT Ironman
Nice work and great writeup. The 8.8 Spartan came out a while after i did the aussi so i wondered how it might have worked. Glad to see it's a direct fit. Hope you make good use of the added traction!
__________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#4 |
Evil Asian
Elkridge, MD
91
One good thing about the Spartan is that its made by Yukon gears and it has a hardened shaft already..
#5 |
Smyrna TN
2004 Explorer XLT 4x4
Nice! How much did it cost?
__________________ 2004 Explorer 4x4 KMC HOSS 16X8, 265/75/16 Mastercraft MT's rear spacer lift, Spartan Locker 1.5" Body Lift, F150 tow hooks Rock Sliders, BTF upper control arms QA1 coilovers front extended sway bar links. Future Mods include 4.56 gears, Limiting straps . My Build Thread http://www.explorerforum.com/forums/...d.php?t=356654 |
#6 |
Ashland Va
2005 Xlt 4x4
I've seen them just under 300... Cheapest locker I've seen....and made by Yukon!
http://www.google.com/search?q=8.8+s...iw=615&bih=369 __________________ Factory DVD, third row, rear A/C, Moon roof, Advancetrac RSC, Tow package, Leather everything, Eddie Bauer running boards.MODS- deep transmission pan w/dipstick, 1.5" Body lift, Expedition front tow hooks, Treadwright Guard Dog M/T 265-75/16 C Ply, Telescoping steering wheel mod, 4.56 gears limited slip front and rear,brembo brakes,front skid plate, Cb.FUTURE MODS-rock sliders, oba, steel front bumper w/ warn VR12000, possibly a M90 |
#7 | |
Smyrna TN
#8 |
Florence, SC
2003 Explorer
Yes, I paid $288 w/ shipping. It's made by Yukon and comes with a hardened cross shaft pin. It doesn't say anything about it fitting the 8.8 IRS but it did perfectly. The way they set up the locker with the springs and pins was a very good idea.
http://www.ringpinion.com/Content/Ho...structions.pdf That's the manual on how to put the locker together. __________________ 2003 Explorer 4.0 Volant CAI Volt HID headlights/DDM Tuning HID fogs BTF (2/1.5) spacers Underdrive pulley Spartan Locker |
#9 |
North Jersey
'97 Mountaineer 5.0L HO
Great deal! This is exactly what the 3rd gens need. With a super rigid frame and IRS it rlly doesn't take much to lift a wheel even with the sway bars disconnected.
__________________ Green '02 Explorer XLT 4.0 SOHC, Max tow package. Snorkel, BWM, On board air, 4.10s w/Trac-lok diffs, 32" T-W Warden A/ts on 16" American racing Baja wheels. Excursion tow hooks, Icom 706mkIIg w/AH4 rig |
#10 |
Virginia
2008 XLT Ironman
I've updated the Aussie Locker install thread in the stickies to mention that the Spartan locker is a direct fit install. Hopefully that will encourage more people to start doing this now.
#11 |
B
Should it still be a direct fit if I do a 4.10 or 4.56 swap?
Still trying to understand how gearing works. |
#12 | |
Virginia
2008 XLT Ironman
Quote:
However, with 4.56 gears you will probably have to grind the edge off one of the ring gear teeth to allow the cross pin to be inserted into the carrier. As I understand it, this is done frequently with all the higher ratio gears and it has no impact on anything. __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#13 | |
Florence, SC
2003 Explorer
Quote:
I hope so too. __________________ 2003 Explorer 4.0 Volant CAI Volt HID headlights/DDM Tuning HID fogs BTF (2/1.5) spacers Underdrive pulley Spartan Locker |
#14 | |
Ashland Va
2005 Xlt 4x4
Quote:
Im going 4.56 and I'm most likely get the noched pin allthough they don't have but a yr or so warranty on the ring and pinion... __________________ Factory DVD, third row, rear A/C, Moon roof, Advancetrac RSC, Tow package, Leather everything, Eddie Bauer running boards.MODS- deep transmission pan w/dipstick, 1.5" Body lift, Expedition front tow hooks, Treadwright Guard Dog M/T 265-75/16 C Ply, Telescoping steering wheel mod, 4.56 gears limited slip front and rear,brembo brakes,front skid plate, Cb.FUTURE MODS-rock sliders, oba, steel front bumper w/ warn VR12000, possibly a M90 |
#15 | |
Virginia
2008 XLT Ironman
Quote:
Didn't think about the warranty thing, good point. __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#16 |
Smyrna TN
I ordered mine today! Can not wait to get it.
#17 | |
Virginia
2008 XLT Ironman
Quote:
So I guess the whole notched cross pin thing vs notching the gear tooth doesn't really come into play unless you're doing a lunchbox locker or spider gears __________________ Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts My Rig:http://www.explorerforum.com/forums/...47#post3004247 |
#18 |
Virginia
2008 XLT Ironman
#19 |
This is AWESOME!!!
#20 |
Florence, SC
2003 Explorer
It's awesome. I have enjoyed having it so far this week. I can't hear it with the radio on. With the windows down and radio off while in a tight turn I can hear it barely. If you are very light on the pedal from a stop into a turn, it will unlock and won't make any noticeable noise. It was worth every penny in my opinion.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| aussie locker install how to: solid axle 8.8 (pics+video!) | LONO100 | 2001-2005 Explorer Sport Trac | 34 | 04-10-2013 07:57 AM |
| How to: 3rd Gen Aussie Locker Install | Ronin8002 | Modified 2002 - 2005 Explorers | 49 | 08-22-2012 10:58 PM |
| !! 911 !! Aussie locker help please! | brianjwilson | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 7 | 06-14-2008 01:42 AM |
| Thread Tools | |
