mthomas4147
- April 21, 2012
- 1991 Explorer XLT
Hello Again, this forum has been most helpful in bringing my old '91 back to daily driver status - approaching 300K miles with one rebuild on the engine and transmission. Latest maintenance issue was resolved by replacing fan, fan clutch, water pump, and serpentine belt. All went smoothly, after reading a variety of posts on what to look out for... so thanks for that. The last thing I did was to wash off the corrosion on the battery cable clamp and flush the battery tray with clean water. I buttoned up the project, checked the coolant levels etc and called it a day.
In the morning I started the engine, and noticed that the fuel gauge was reading 3/4 full, but I really didn't pay attention as to what the needle did on startup - and this is the crux of my question to the group -
I simply can't remember if the fuel gauge needle just stays at the current fuel level when the engine is shut off, or does it do a reset from E and then travel to the current fuel level ? I ask this because I know that the fuel tank is full, to the filler neck. And now it's showing only 3/4 full.
If I turn off the engine, and then restart - the fuel gauge needle backs up to 1/2 full and then travels to the 3/4 position - AND a bit more. So if I do this process 3-4 times I can get the gauge needle to move a bit more after each attempt and now it's reading Full. I'm not sure if it's going to stay there, or drift backwards or report correctly from here on forward.
Summary of questions >>
1) what is a correctly functioning fuel gauge supposed to do on engine shutdown / and then startup. ie stay at current level or do some sort of reset?
2) Any ideas as to what has caused/ or is causing this issue? And could it be related to any of the service items I covered when I changed out the waterpump , battery cleanup etc?
3) And lastly Is there any way to force a reset to the fuel gauge to "zero" it out, so at least I know it "knows" where the starting point is for fuel level..?
Thanks again for all the assistance.
Mike
Mike
