Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rumble noise at 60-65 MPH
Reply
Thread Tools
Old 09-23-2012, 04:59 PM   #1
davem
Rochester, MN
'01 XLT
Vehicle Specs
Quoted: 18 Post(s)
(Original Poster)
My 2001 Explorer XLT V-6, with 133K miles, has developed quite a rumble when I get to around 60 MPH which gets worse as I increase the speed. (The condition probably exists a bit at lower speeds, just less noticeable.)
Its kinda of a rumble/loud hum, and includes some degree of vibration in the floor.
I put it on ramps today and looked for anything obviously loose or broken, shook a few exhaust parts, and did not really find anything.
Any suggestions ? Check tire balancing ? U-joints ? (they really dont make a 'clunk' sound when I put in in gear.)
Thanks.
davem is online now   Reply With Quote
( Join the Elite Explorers )
Old 09-23-2012, 06:18 PM   #2
tchalm
Hillsboro, OR
98 Explorer XLT
Vehicle Specs
Quoted: 2 Post(s)
A few experiments will teach you a few things.
If it's a problem with the tires they usually show weird wear patterns. Try changing the air pressure up or down by 5 lbs, and see what happens to the rumble. Then go back to the correct inflation after that experiment.
Also try rotating the tires to see what happens to the noise.
Then try getting the tires balanced, and see what that does.
If the tires all check out OK, then start looking at the other parts: U-joints, CV joints, transmission (should be serviced annually anyway), transfer case, etc.
TC
__________________
98 Explorer 4L SOHC, 262K miles, stock, daily business truck.
My other ride is a 90 Bronco II (Pre-Gen 1 Explorer Sport) 216K miles, For Off Road Driving (or just getting around town).
tchalm is offline   Reply With Quote
Old 09-24-2012, 05:08 PM   #3
davem
Rochester, MN
'01 XLT
Vehicle Specs
Quoted: 18 Post(s)
(Original Poster)
Tires have been rotated and re-balanced (by tire place where I bought them).
No change in rumble/vibration.
Taking to my general repair shop tomorrow, I hope.
Old 09-26-2012, 09:13 AM   #4
davem
Rochester, MN
'01 XLT
Vehicle Specs
Quoted: 18 Post(s)
(Original Poster)
The front right wheel bearing was worn out and needed replacing.
Problem solved.
Cost $480 for parts and labor.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Explorer Shaking at Highway Speed (60 - 70 mph) XCAMP Stock 2002 - 2005 Explorers 32 04-22-2015 07:41 AM
Vibration/chatter from 60 mph up calthaus Stock 2002 - 2005 Explorers 9 04-30-2012 10:18 PM
Whining noise at high RPMs btmcbride Stock 2002 - 2005 Explorers 2 06-03-2009 11:13 PM
Noise at back remimo Stock 2002 - 2005 Explorers 8 09-27-2007 06:21 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
