Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
PRNDM light staying on
Reply
Thread Tools
Old 12-27-2012, 07:01 AM   #1
Brownie11
2011 XLT AWD
Vehicle Specs
(Original Poster)
'11 XLT -- After exiting the vehicle, letting all the various lights and screens "time out" and shut off, the PRNDM shift-position indicator light in the speedometer is staying on (indefinitely). Also noticed that the red highlighted gear position isn't lighting. If you fiddle with the shifter lock button, and can get the red highlight light to come on, then the PRNDM light will properly go out along with the domelights, etc. The Dealer admits it's odd and is going to do some research to figure out what part to order and how to fix this. Will keep you updated, but thought in meantime someone might have similar experience?
Brownie11 is offline   Reply With Quote
Old 12-27-2012, 07:20 AM   #2
OneofMany
Georgia Mountains- Talullah Falls
94 expl 4x4
Vehicle Specs
Not that im an expert on that particular vehicle but from previous experience it sounds like there is an ignition switch issue. the gear selector and ignition switch are linked and are often problematic. try wiggling the ign. switch and gear selector.
OneofMany is offline   Reply With Quote
Old 12-27-2012, 08:16 AM   #3
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Welcome to the Forum Brownie11.
The way you are describing the problem it almost seems like it is a issue with a poor electrical contact since wiggling the shifter. I don't recall a similar post with this problem although other members ahve reported getting a 'Shift to Park' message after parking their vehicle. It seems that was cured by replacing the shifter.
By the way, if you add 'XLT' after 2011 in the left column profile you won't have to identify your Ex model everytime you post.
Good luck and Season's Greetings.
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is online now   Reply With Quote
Old 12-28-2012, 03:04 PM   #4
FordCustSrvc
Official Ford Rep
Dearborn, MI
FordCustSrvc's Avatar
Vehicle Specs
Hi Brownie11!
You've already done what I would advise off the bat - you went to your dealership! Additionally, I am happy to get your case escalated to your regional customer service manager. Just send me a PM with your VIN, dealer, mileage, daytime phone number, and full name; I'll get things rolling.
Great suggestions, OneofMany and Peter!
Have a great weekend,
Crystal
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordCustSrvc is offline   Reply With Quote
Old 02-14-2013, 05:58 AM   #5
keithd
Ford Explorer 2011
Vehicle Specs
2011 xlt gear lights stay on
Same problem, but of course it doesnt do it at the dealer, its like taking a kid to the doctor, he gets well immediately. If they can't duplicate problem after today ill pick the vehicle back up and wait til it happens again. Glad i got the extended warranty. This will be the last Ford I EVER buy.
keithd is offline   Reply With Quote
Old 02-14-2013, 08:45 AM   #6
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
I assume that your last statement is based on more than just this post!
My 2011 has been virually flawless over the almost 2 years I've had it. Of course if I had a extended list of problems that I've had with it, I would likely also share your feeling. FYI, I have seen a few similar posts by members on the Toyota Highlander Forum about their vehicles when I was active on there.
__________________
Old 02-16-2013, 08:52 AM   #7
Brownie11
2011 XLT AWD
Vehicle Specs
(Original Poster)
The dealer replaced the gear shift lever...and now all is well. Note to Keithd: the problem was intermittent, but I found that if I left the selector in PARK and toggled the release button on the backside of the shift lever, I could often duplicate the problem.
Old 02-16-2013, 08:22 PM   #8
vig1116
monmouth, NJ
'11 Limited
Vehicle Specs
this is happening a lot more often than i realized.... This has been the biggest headache for me the last 3-4 months or so trying to get it fixed....
vig1116 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
dome light turns off, when headlights pulled on bozo4ford Ford Ranger - Mazda B-Series Forum 0 09-19-2011 10:32 PM
94 xlt check oil light is staying on explorernoobie Stock 1991 - 1994 Explorers 0 08-18-2011 12:18 PM
1st and 2nd Gen Light Guide! BrianDye Performance Lighting 11 01-12-2010 10:43 PM
Theft light staying on. akvanden Stock 1995 - 2001 Explorers 1 01-10-2010 10:22 PM
Glove Box Light Assembly - 2006 X jdc28va Stock 2006 -2010 Explorers 1 12-18-2008 12:04 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
