- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Coil Over Conversion Progress...
There is some visable progress on my coil over conversion. The upper links are finished and their mounts are nearly complete. In fact the right side is complete and the left was being finished while I was there today.
After that they will beef up the lower link, make some modifications to the upper shock mount to allow the shock mounts to be turned 90 degrees from what they were and that's about it.
The photo shows the front axle resting on the ground on the left side. It's actually going to have a limit strap to keep it from going quite that far.
Bump stops will be Bilstein hydraulics.
It should be sitting on the coil overs by the end of the week. At least that's the projection at this time. The shop has access to a huge variety of loaner springs so we will start with 450lbs and go from there.
