HELP! Fuse Box question | Ford Explorer Forums
padeerslayer03
Jeannette, PA
93 Explorer
On my 1993 explorer XL.
I was hooking up my system last night and when it was time to run the blue wire into the fuse box, i noticed i idnt have a fuse box cover.
can someone show me a pic of the cover so I know which outlet to plug it into??
Thanks!!
you can't hook it to the fuse box because the fuse box is always hot. You need to hook it to the ignition wire on your cd player
Not all fuses in the fuse box are constant hot. Some are run off ignition power.
Sorry I can't help you more man, I don't have a 1st gen around right now.
well i already tried the radio one on mine and it wont work i know. But i dont know whats diferent about your gen. It would just be easier to hook it up behind the cd player
There is a radio fuse that is IGN. I hooked my radar detector up to this one, but the remote wire is best being wired to the HU.
Ok, here is my crude picture of the fuse block locations:
For a 94...93 is the same:
From the 94 manual:
1 15A Dome lights (Power mirror 2 door) Radio Memory
2 6A C.B. Front washer/Wiper
3 Not used.
4 15A Stoplamps 4 Way flashers
5 15A Back up lamps DRL(Canadian) Rear defroster Turn signals, Turn indicators
6 10A Speed Control
7 15A Cluster warning lamps
8 20A Horns
9 10A Air conditioner switches Clutch coil
10 15A Parking/Licence plate lights Trailer tow
11 15A Radio (switched) power
12 20A C.B. Cigarette lighter Flash to pass
13 10A Instrument panel illumination
14 30A C.B. Power windows
15 10A ABS module
16 20A Premium radio amplifier
17 15A Rear wiper/washer
18 15A Heated exaust gas oxygen (HEGO)
everything is hooked up!
the 15"s are BUMPIN!
Thanks!
I just need to know is 91-94 the same?
Considering That picture I took is of a 92....and the 94 manual has the same fuse locations....Hmm. I can double check tommorrow if You wish...
From the 94 manual:
3 Not used.
6 10A Speed Control
8 20A Horns
15 10A ABS module
Hello, I am looking for this information but for a Explorer 1995 XLT, could you help me, i have not the owners manual.
Thank you
From the 94 manual:
3 Not used.
6 10A Speed Control
8 20A Horns
15 10A ABS module
Can someone please give me a list of the Fuse locations similar to this for a '99 Ex? I have searched the site already for one.
Thanks,
Geoff
Thanks,
Geoff
pm or email me I have the diagram you need.
I know this is an old thread but Im hooking up my new CB radio and was wondering which fuse would be the best to hook into? I was thinking the rear window wiper or cigarette lighter
i hooked my cb into #3 and its been working fine for a couple years now
