Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
need to remove fan clutch assy...
Reply
Thread Tools
Old 12-26-2003, 05:46 PM   #1
jaygecko
tampa florida
'94 ranger splash
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i need to remove the fan clutch from the water pump so i can finish changing the water pump on my 94 4.0 ranger. i am in the middle of changing the complete cooling system as well as trying to get an efan on to replace my broken plastic stock fan.
im trying to work on the truck and im running into the same problem i ran into last time and couldnt change...i cant get the fan clutch and fan off of the waterpump pully on my 94 4.0.
i went to autozone and they gave me the removal tool set which happened to contain the 5 pieces that didnt fit my application, so i went back to them and they gave me the "correct" kit which only contained 2 wrenches.
and going by the pictures in th ehaynes manual, it looks like one wrench fits over the bolts on the pulley pump to keep that from turning, but the other damn wrench in the kit is still too big for the large nut (now im not sure if some one else filed this wrench to fit their application since it looks like the edges have been worn back to the silver metal and its too big for that nut.
i tried an adjustable wrench but i dont have one that opens up large enough to fit over the nut. does anyone know what size that nut is that holds the fan clutch to the water pump?
or any methods of how else i can get the damn thing off of the truck so i can go about finishing the work?
thanks in advance
__________________
1994 Ford Ranger Splash w/ a Vortech blown 4.0 5spd
jaygecko is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-26-2003, 06:25 PM   #2
Gimp
The Beach
Gimp's Avatar
TOTALED 1994 XLT
Vehicle Specs
Quoted: 0 Post(s)
Re: need to remove fan clutch assy...
According to this, http://draco.acs.uci.edu/explorer/ , it's 1-7/16". Read through the write-up and see if it offers a tip that might be useful to you.
Good luck.
Gimp is offline   Reply With Quote
Old 12-26-2003, 10:03 PM   #3
jaygecko
tampa florida
'94 ranger splash
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks.
that did confirm my thought about how i was supposed to hold the pump and stop it from turning, but im going to have to see if my luck will bebetter or at least have some descent assistance at the autoparts store getting the right set of loaner tools now. might just buy them instead so i never have to rent them again tho.
__________________
Old 12-27-2003, 08:14 PM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
I too rented/borrorwed the fan clutch tool from Autozone for our '92.
The big wrench that hold the pump from turning (the one that kinda grabs 2 bolts) was spread out. I just took out my trusty coarse adjustment tool (e.g. my 2.5 lbs sledge) and whacked the wrench until it fit tight on those 2 bolts that it grabs.
I was then able to get the fan clutch off...
BUT, I have since found a much better way to do it (I'm even going to add the tool to my toolbox)... Basically, it is just the wrench part that goes on the shaft behind the clutch... that is kind bent at a 45 degree angle... This is so I can put the end into an air hammer (i've also done it with my coarse adjustment tool). When you hit the trigger (or hit it with the sledge) it pops right off... I couldnt' belive how easy it was to do...
I have even used the rental too from autozone this way (I didn't have the "neat" tool yet).. I just put the one piece behind the water pump, and set it at an angle that I could put a big combo wrench on the end (open end just sat on the autozone part) and whacked it.. It took a couple wacks, but it came right off...
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 11-18-2010, 12:58 PM   #5
tattmandue
ozark missouri
1994 mazda Ford
Vehicle Specs
Quoted: 0 Post(s)
I already have threee of these bolts off the clutch and all the bolts off all the assembly. I just want the clutch off. How do I hold the clutch still without breaking it?
tattmandue is offline   Reply With Quote
Old 11-18-2010, 02:13 PM   #6
TexasArmadillo
N 29.554349 W 95.295959
10' Explorer XLT
Vehicle Specs
Quoted: 2 Post(s)
I had the same problem with my 90' F-150. What I did is a little unorthodox. I bought a 2" adjustable wrench and fitted it on the nut. I then braced it on the body, and cranked my engine. I did not turn it over, just did a quick little start. It loosed the bolt enough to remove it. Like I said it seemed crazy at the time and I still get the apprehensive thinking about it, but it worked. Use this one at your owe discretion.
__________________
"I've never had a normal time in Texas, but at least it was fun".
-Mike Rowe
“My four food groups are pie, salt, bourbon and bacon,” -Navy Lt. Cmdr. Morgan Murphy
Dillo Mobile "SOLD"
Copper Top
TexasArmadillo is offline   Reply With Quote
Old 11-20-2010, 11:35 AM   #7
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
If you get the right water pump pulley and fan clutch nut wrenches it comes off just fine. Get a caliper and measure the sizes you need then cobble together the wrenches from different loaner kits if you have to. I remember reading about a guy trying to bump the engine over with a breaker bar on there and he sliced his hand open. I don't remember which thread but I definitely remember seeing it.
__________________
There is wisdom to be found in the counsel of many.
OneLever is offline   Reply With Quote
Old 11-23-2010, 01:33 PM   #8
Fifty150
Frisco
97 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
A pry bar will hold the pulley bolts.
An adjustable Crescent wrench will fit on the nut.
Fifty150 is offline   Reply With Quote
Old 05-26-2011, 04:23 PM   #9
olemech
bradenton fl
1996 xlt 4dr 4x4
Vehicle Specs
Quoted: 0 Post(s)
fan clucth
i have a maco tool kit which the wrench fits into airhammer and you don't anything to hold engine. kit come with all sizes of wrenchs to fit fans, i have found one fits all.
olemech is offline   Reply With Quote
Old 05-26-2011, 04:30 PM   #10
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
Quote:
I got to use a Snap-on one that sounds like that.. I thought it was the greatest thing since sliced bread.. it worked so well.
~Mark
__________________
Old 10-18-2011, 05:16 PM   #11
bloody45fsw
Fullerton, California
1991 Ford Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
oh man, i got to do the same thing to my 91 explorer, funny thing is that now the only way im going to get this done is by getting the loaner tool, just hope my truck don't over heat on the way there.
bloody45fsw is offline   Reply With Quote
Old 10-18-2011, 05:58 PM   #12
Jestarr
New jersey
99 X sport
Vehicle Specs
Quoted: 0 Post(s)
I removed the belt and used a strap wrench and large adjustable wrench... Worked great
Jestarr is offline   Reply With Quote
Old 10-20-2011, 02:27 PM   #13
Dono
V8 Limited and SC 4.0 OHV
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 462 Post(s)
I fought with mine, it won.
I bought the ford tool. $100.00
Too bad shipping is so expensive, id be happy to lend it around.
__________________
00 Limited V8 rear mount turbo http://www.explorerforum.com/forums/...d.php?t=388599
and a Rebuilt SC 4.0 OHV.
Dono is online now   Reply With Quote
Old 10-20-2011, 03:32 PM   #14
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
O'reilly sells the Performance Tool wrench, it's the same one as Ford. $20... Return the Ford one and get the cheaper one. Info is in my rad thread. Just stick a prybar between two water pump pulley bolts.
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 10-22-2011, 05:00 PM   #15
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Quoted: 14 Post(s)
The wrench set is $17 on amazon.com, free shipping if you find $8 more stuff you want.
http://www.amazon.com/gp/product/B004KEJXGE
The wrench and hammer method is a great idea... I have a big crecent wrench and a big hammer, it would have worked, probably easier.
Roadrunner777 is offline   Reply With Quote
Old 10-23-2011, 07:08 AM   #16
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
I got in a jam for a tool also on a BMW job but just took a piece of scrap 1/4" flat bar, cut the 32mm (1 1/4") hex into it and welded it onto an old never used handle. Cost: $0
Measure the hex on your new fan clutch so you KNOW what size tool to buy/borrow/make.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 10-30-2011, 08:17 PM   #17
muzzymaniac
Kent, NY
04 Explorer XLT 4.0L
Vehicle Specs
Quoted: 0 Post(s)
I used one of these on my old Blazer. Haven't had the need to try it on any others but I don't see why it wouldn't work.
http://www.amazon.com/Ridgid-31170-1.../dp/B001HWJ6ZA
Worked like a charm for me.
muzzymaniac is offline   Reply With Quote
Old 11-03-2011, 10:39 PM   #18
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 181 Post(s)
O'Reilly auto parts (and maybe Checker/Schucks/Kragen) sells the Performance Tool version for $19.99 + tax, a good option if you need one ASAP.
Advance Auto Parts used to sell the Performance Tool version, but now sells it as their Autocraft house brand (Part # AC660) for ~$24.99. Keep in mind their warranty seems to allow for in-store exchange, which is pretty good when it comes to hand tools. You have to send back most others to the manufacturer. There are also plenty of online coupons for advanceautoparts.com, and you can buy online with coupons and pick up at your local store. I bought both the tool and the Dorman 9-blade radiator fan, and with a $10 off coupon it was less than buying the tool itself. Pretty good deal.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 03-12-2012, 05:09 PM   #19
-tristan-
LA
93 Exploder
Vehicle Specs
Quoted: 0 Post(s)
Fan Clutch Removal Help
hoping you guys can help if you can remember...
which way do you turn the nut to remove the fan clutch on 93 explorer?
I just looked it up on Mitchell on demand. Says clockwise while looking at it from front of vechichle. Is that correct?
Unfortunetly, I looked this up after trying, could i have damaged it in trying to remove it in the wrong direction??
Thank you for your help.
-tristan- is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
