lonestar
- August 29, 2001
- lou,ky
- 91 XLT, 02 XLS
I was haveing a starting and idling problems which caused the engine to sputter and die, but was fine while driving. I checked the fuel pressure and it seems to be low. I started this new thread to help people using search.
After installing guage and priming fuel system by tuning key to run pos, it read 35 psi. After starting it slowly bled off to 20 psi in about 5-10 min ans started idling rough. I also tried to remove vacuum line to regulator and pressure did not change. When I removed fuse for pump and pressure dropped to about 18, it gave all the sputtering symptoms I was having.
According to Haynes.
Pressure with vacuum hose attached - 30-45
Pressure with vacuum hose removed - 40-50
Max Fuel pump pressure 65 psi
I changed the fuel filter less than 3 months ago, after it was completly clogged, would not run longer than 1-2 minutes. Previous owner had new pump installed, maybe it's fried though.
Is there anyway to check fuel pump output pressure?
