dino11
- November 19, 2009
- Princeton, ky
- 02 exploder
i am certain that i have a front wheel bearing bad. i am cheap and plan on running it until it gets worse.
i cannot locate my haynes book, and am confused with search results
i know on the previous gen explorer, you cannot replace the bearing itself but have to replace the entire hub assembly.
i have access to the proper tools and equipment necessary to do both jobs.
my question is which is recommended? if i put quality bearings in, shouldnt that last as long as a whole assembly? assuming they are installed correctly?
the po claims he put new bearings in all around about 30k ago, but i am suspicious of simply replacing the bearings because they only lasted 30k.
i searched but didnt see a writeup on bearing replacement, just the hub assembly.
or am i simply confused and this isnt possible? haha. thanks
