tjgorn01
- September 2, 2008
- Louisville
- 02 Aviator & Mntr AWD 4.6
My son told me his 02 Mountaineer AWD 4.6V8 w 175K was shifting hard and felt like it was slipping as well. I test drove it and got a very hard shift into reverse and would shift hard from 1-2 at higher RPMs/acceleration and more smoothly when accelerating gradually. No OD or SES lights. On his way back from a short trip calls to tell me OD light is flashing and SES light is on.
I check it this morning and pull a P0755 code off of it (Shift Solenoid B issue). I then reset the codes and drive it around to try and reproduce with no luck. Park it. Just went back out to mess with it a bit and now it will not engage into ANY gear. Can shift into any gear but in reality it is in neutral at all times. The vehicle and can be pushed whether in R,N, or D. No flashing OD light or SES light.
Transmission only problem or a combo?
