wallyw
- February 4, 2015
- 2004 Mountaineer
This forum has been an amazing education so far.
I have a 2005 mountaineer v6, only 59k miles, that has been having the hard shifts for a while with o/d light coming on indicative of the servo bore issue. Foolishly I ignored it for too long since I only drive this vehicle 1-2x/week.
Recently it lost reverse. Reverse will rev in what sounds like short cycles but nothing moves.
I'm worried it's a broken band, but it does have manual 1 and 2 just fine. I'd seen some discussion that if the reverse band is broken manual 1/low won't work? All the drive gears work but the rpm's get high and it struggles to shift into 3rd and overdrive and drops out of overdrive sometimes.
Is there a way to diagnose a broken band just through the band adjustment bolts? Or do I need to drop the pan and pull the servo pin to inspect the band?
Basically I'm trying to figure out if I should just swap the solenoid pack and/or valve body as a preliminary step or go straight to a shop for a rebuild to fix the band and whatever else may be wrong. It seems like most shops want to just do a rebuild and not do honest diagnosing. I tried one shop and ran away when they claimed "the car computer shows the band is broken" without doing any other diagnosing.
It is throwing the following codes:
P0795 - fault - pressure control solenoid c
P0775 - pending - pressure control solenoid b
P0731 - gear 1 incorrect ratio
P0732 - gear 2 incorrect ratio
P0734 - gear 4 incorrect ratio
P0735 - gear 5 incorrect ratio
Any guidance much appreciated!
