1996B4000
- January 25, 2022
- Heathsville VA
- 1996 B4000 LE
The fuel filler tube -- which I think is a piece of flex tubing between gas tank and filler cap. If I fill up full, I get fuel leaking from the filler tube. So, I keep the tank around 7/8 full.
The guy who does the work on the truck says the bed must be removed to replace the filler neck hose.
Is this right -- do i need to pull off the entire bed to REPLACE the filler tube
