mike684720
- April 3, 2024
- Hudson
- 1998 Explorer XLT AWD 5.0
Hi all, I am new to this forum but am looking for a little help. I've had my 98 Explorer since new (~250,000 miles), but a couple weeks ago it started dying when you try to put it into gear. Idles great, shifts great (when driving), but dies when shifting into gear (when warm) unless you hold some extra RPM's into it. If you do hold the RPM's, you can get it into gear and drive it fine.... but if you stop quickly (without adding RPM's), it will stall (kind of like a manual car would). It will allow you to shift into gear immediately after cold start because the idle is still higher at that point. I have cleaned the MAF and the IAC and then took it to a shop and they have replaced the EGR (after finding a leak) and then they replaced the TCC solenoid. No overall change so far and they are out of ideas and searching the net for answers. I have read other posts about checking the #13 fuse in the engine compartment and also unplugging the battery for a while to reset the computer, but have not asked the shop to try these yet.
Anything else that you can think of? I am literally looking for a silver bullet.....
Mike
Mike
